Username Post: Air Conditioner recharge        (Topic#348596)
Buddy Mewbourne
Buddy Mewbourne
Loc: Talladega, Alabama
Reg: 03-04-04
12-07-17 05:08 PM - Post#2717224
I have an after market air conditioner set up in my 39. I need to recharge the system. The quick connect hose that I have won't fit the low pressure outlet on the compressor. Do they make different quick connect fittings? Never run to this problem before.
Second Bridge Garage
Chevs of the 40s
12-07-17 06:45 PM - Post#2717229
    In response to Buddy Mewbourne
Maybe it is the high side fitting? Which won't fit the low side. or you are using old style r12 fittings?
Buddy Mewbourne
Buddy Mewbourne
Reg: 03-04-04
12-08-17 02:55 AM - Post#2717269
Thanks Shepard. I'll try that. Don't know if I'm trying to use an old R-12 fitting. I'll check.
Ray P W
Reg: 09-30-15
12-08-17 10:00 PM - Post#2717371
Buddy,
I have an R12 gauge set that I also use on our R134 cars. All it took to be able to do that was an inexpensive adapter set from O'Reilly Auto Parts.
Ray W
Chevs of the 40s
Execution time: 0.311 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:19 PM
