Username Post: 4x4 incomplete engagement - disengagement        (Topic#348586)
93 Silverado
93 Silverado
Reg: 07-14-14
12-07-17 06:25 AM - Post#2717170
'93 Silverado with floor shifter: It makes a clicking sound when trying to disengage (sounds near the hub) but eventually stops after a long time (I imagine the end of a spline or coupling getting damaged). Additional information: The actuator is new (thermal type, non-GM). Also, one time the front-end strangly "bucked" - a very rigid feeling, and nothing was exteriorly visible. (Although possibly unrelated to the engaging, my guess is that was a cruch in the differential.) It's currently "useable" but not without regret. Is this a worn half-shaft?
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
12-07-17 09:38 AM - Post#2717188
    In response to 93 Silverado
You sure the shifter is going all the way into gear? It sounds like the actuator is sticking.
Jeff
'88 Chevy K3500, aluminum head roller cam 511inĀ³ stroker 10.5:1 compression, 96 NV 4500, 94-98 grille, 305/70-16 (33x12) BF Goodrich KM2s, 91 cluster swap
Execution time: 0.206 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:58 AM
