Username Post: Heater blowing cold air        (Topic#348565)
bubbanm
Loc: Tennessee
Reg: 04-14-08
12-05-17 02:47 PM - Post#2716971
Hi Everyone,
Back in the summer I replaced the drivers side door blend actuator because I had hot air coming in on the drivers side of the truck. Now its cold weather and the heater is blowing cold air on both the driver and passenger side. It does not do it all the time but sometimes it does. I have the dual climate control and both sides will be blowing cold air when they are set on hot. Sometimes it works fine but other times it is blowing cold air. Any ideas what might be causing this on my 04 Silerado ?
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
12-05-17 03:56 PM - Post#2716975
    In response to bubbanm
  • bubbanm Said:
...the heater is blowing cold air on both the driver and passenger side. It does not do it all the time but sometimes it does.....Sometimes it works fine but other times it is blowing cold air.
I don't know the GMT-800 HVAC system, but in general a vehicle won't produce heat consistently if the coolant is low.....it will come and go. You might check to see that the cooling system isn't super low....does your truck even have a radiator cap, on the radiator?
If it's low, and you have a gauge, the temperature will rapidly climb from cold, to beyond normal, and then drop below normal when the thermostat opens.
99 K3500 RCLB
bubbanm
Loc: Tennessee
Reg: 04-14-08
12-06-17 10:50 AM - Post#2717065
    In response to 454cid
You hit the nail on the head. The coolant was low. I don't have any leaks since I park in my garage I would see them. The coolant must have evaporated since I last changed it a couple of years ago. Can that happen?
12-06-17 11:36 AM - Post#2717071
No on the evaporation...sure hope you don't have the infamous Castech heads issue with your engine.
http://ww2.justanswer.com/uploads/Bluegorilla/2 008...
Time to do a pressure test of your cooling system, see if you can determine where the leak is. Obviously do it on a cool engine so you're not opening the cap on a hot, pressurized system. See if it will hold around 16 psi since that's likely the rating on your cap. Don't over-pressurize it as you can damage the heater core or radiator.
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
12-06-17 02:11 PM - Post#2717093
It could be a small leak that evaporates when it contacts the outside of the hot engine.....or possibly the Castech head issue. I don't know much about the heads since I don't have an LS engine, However.
99 K3500 RCLB
Execution time: 1.008 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:05 PM
