Username Post: Rack and pinion        (Topic#348546)
Joelinda5386
Reg: 07-18-16
12-04-17 11:20 AM - Post#2716848
Is Rack and pinion on a 64impala worth the expense
12-04-17 12:42 PM - Post#2716856
    In response to Joelinda5386
IMO, installing a R&P is much more disruptive than replacing the steering gearbox. The only possible argument I can see for R&P is if you have an unresolvable clearance issue between the steering box and radiator. That can usually be avoided by careful selection of the radiator and/or steering box.
Joelinda5386
Reg: 07-18-16
12-04-17 02:14 PM - Post#2716871
I hve steering issues that no one can solve. Car bounces and wanders all over. I have a new steering box, shocks and seay bar in front
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
12-04-17 03:50 PM - Post#2716880
Have you changed upper a arms? The integral power steering boxes require approx +4 degrees of caster that can't be achieved by the original stamped steel ones (they max out at about 1 degree).
Pete
1963SBHD
"7h Year" Gold Supporting Member
1963SBHD
Loc: south carolina
Reg: 09-01-11
12-04-17 10:05 PM - Post#2716915
NO NO NO NO NO NO....Get the DRIFT ?? NEVER...I have a complete system (got it for a backup) I would not GIVE you..as it is not a safe thing to put on your car. 1. What is does : replaces a push pull slave system with a bolt on (hahaha) rack and pinion (flaming river/Unisteer) 2. What is DOES NOT DO : make your car handle better, track better, drive better...it made mine unsafe to drive, so have removed it. IMHO..either replace the stock components...OR choose the Global West conversion (converts you to a borgeson unit with bump steer elimination ..includes a new sway bar). Several on this forum have made the same mistake. Agree with replacing the stamped steel arms..many vendors including Global West. VIsit their website to look at the videos. Good luck
junky
Loc: Northeast CT
Reg: 06-27-10
12-04-17 10:56 PM - Post#2716918
I had the same problem with one of my Corvairs. It is called "bump steer", and is caused by the center drag link being out of alignment with the geometry of the steering. Mine was the result of using a "grease able" ball bearing idler arm. Once I put back a NOS Chevrolet part, all the problems went away. The shop that did my alignment diagnosed the problem after they did the work, and took it out for a test drive. They were an old shop with Bear equipment. He even had a tin "toy" that he could demonstrate what was happening with the wheels. One of my cars, was the last car that the shop worked on before the owner closed and retired. When I came to pick up the car, he gave me that tin demonstration toy. I would post a picture of it, but right now, I don't know where it is. If I come across it, I will post a picture of it. It shows how the tire/wheel move to a "toe in" position when the car bounces as it goes down the street.
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
12-05-17 04:20 AM - Post#2716927
Is your present steering completely stock?
Member #2194
models916
Loc: Addison, IL
Reg: 05-28-10
12-05-17 07:12 AM - Post#2716932
    In response to DonSSDD
This will fix it.
http://www.globalwest.net/1959-1960-1961-1962-1 963...
omarine
Loc: San Diego
Reg: 06-29-15
12-05-17 10:13 AM - Post#2716950
A rebuilt front end handles well if the control arm bushings /sway bar bushings, etc are all new. Don't even need expensive poly kit.
Also many people forget suspension, drop spindles change your geometry - lowering springs might be better for that.
And please remember to adjust your steering box per factory specs. It needs the worm gear and lash adjusted in that order with pitman arm disconnected using a fish scale at the steering wheel. The book outlines the procedure well.
Once all that is done, and alignment is done correctly, and well balanced good tires, car should handle like new if frame has never been hit.
cheers
Oscar
61 Impala bubbletop, 283, 2bbl Rochester, generator, points and drum brakes- daily driver
'49 Harley Davidson FL - Panhead
Edited by omarine on 12-05-17 10:15 AM. Reason for edit: No reason given.
12-05-17 12:26 PM - Post#2716960
    In response to omarine
  • omarine Said:
.....Also many people forget suspension, drop spindles change your geometry - lowering springs might be better for that.....
I think you will find a lot of people who take issue with that statement.
Lowering springs "raise" the control arms with respect to the rest of the suspension. How can that NOT change the suspension geometry?
Drop spindles leave everything exactly as it was except for moving the wheel axis up. The wheels can't really move up because they are in contact with the ground, so the rest of the car moves down. Nothing else changes.
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
12-05-17 05:30 PM - Post#2716987
Drop spindles do NOT change the steering geometry. Short springs changes the geometry.
55Brodie
55Brodie
Loc: Little River, SC
Reg: 12-26-15
12-05-17 07:14 PM - Post#2716995
    In response to Tri5man
Dropped spindles could affect bump steer if the steering arms no longer remain in the same plane as the original spindles. In other words, you want the tie rods as close to parallel with the ground as possible with the car at ride height.
omarine
Loc: San Diego
Reg: 06-29-15
12-06-17 09:34 AM - Post#2717060
    In response to 55Brodie
Edited by omarine on 12-06-17 09:44 AM. Reason for edit: No reason given.
omarine
Loc: San Diego
Reg: 06-29-15
12-06-17 09:44 AM - Post#2717061
it's possible my statement about dropped spindles is inaccurate, all I know is that after installing 2" lowering springs on original spindles, my handling seemed to improve. Might be in my head.
12-06-17 11:15 AM - Post#2717066
Lowering with springs or any other way may improve the handling just because you are lowering the car's center of gravity.
omarine
Loc: San Diego
Reg: 06-29-15
12-06-17 01:19 PM - Post#2717090
Agree Ray, I have not noticed any negative side effects by going to lowering springs. I got them new versus trying to cut a coil from the old springs.
Car handles excellent with all the attention given to it that I posted above.
cheers
Oscar
Execution time: 0.307 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:55 AM
