Username Post: Belts        (Topic#348536)
AmericaMade
Reg: 11-06-17
12-03-17 05:52 PM - Post#2716790
Looking to replace the power steering, alternator belts etc.
Are the belts all the same? Also can anyone link me the correct ones or part numbers to order. Thanks
1983 C10 Scottsdale V8 383 Stroker
LMC Truck
Senior Chevytalk Moderator
12-04-17 05:07 AM - Post#2716815
    In response to AmericaMade
From which parts store or website?
Are accessories stock? Are pulleys stock, painted, or chrome?
AmericaMade
Reg: 11-06-17
12-04-17 08:09 AM - Post#2716834
Not seat belts..
Drive belts, power steering belts not belts for your pants.
Id like to replace these and was wondering if theyre all the same or different belts and if so, can anybody recommend belts theyve used for replacement of the above belts listed.
Amd if theyve have used a specific belt do they have a link or site they recommend in purchasing the belts.
Thank you.
12-04-17 09:22 AM - Post#2716842
Gates belts. Probably the best prices are from www.rockauto.com.
You can use a piece of rope to measure exact size. The rib should not ride completely down in the V groove. It should be up slightly up the groove.
LMC Truck
Execution time: 0.228 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:21 AM
