 Page 2 of 2 <12
Username Post: 55 chevy power steering        (Topic#348519)
12-21-17 06:26 PM - Post#2718718
    In response to Frankman
The small wheel will exaggerate the faster steering even more.
Jalapeno
Jalapeno
Loc: The Republic of Texas
Reg: 04-30-00
12-21-17 08:46 PM - Post#2718727
    In response to 55Sedan210
  • 55Sedan210 Said:
Going to be doing the power steering upgrade on a 55 sedan. Do I need to replace the pitman & drag link? Original manual car.
Welcome to Chevy Talk.
No need to change the manual linkage stuff if you go with the 500 gear and its siblings. I would replace the link and idler bushings if they are worn, and make sure the pitman arm ball is not out of round.
Jalapeno
Frankman
Gold Supporting Member
Frankman
Reg: 09-25-17
12-26-17 08:02 PM - Post#2719060
Ok so I'm getting a little confused, I have received my complete front suspension rebuild kit.so I'm thinking all I need is the 500 power steering box right? Than I read some more on suspensions and it seems like there is a difference between a manual steering & power steering suspensions. So did get the wrong parts or not. So here are the parts I got from Danchuk complete front suspension rebuild kit part #18770 with 5 degree positive caster upper control arm, so can someone tell me if this will all work with 500 power steering box.
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
12-26-17 08:28 PM - Post#2719068
I went to the Danchuk website and looked up your part number, and it said it will work on any 55-57 Chevy. And yes, it will work with a 500 box.
Frankman
Frankman
Reg: 09-25-17
12-26-17 09:51 PM - Post#2719075
    In response to 5Larry7
Ok thanks I was starting to get worried, thank you for your reply.
 Page 2 of 2 <12
Execution time: 0.426 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:23 PM
