Username Post: 55 chevy power steering        (Topic#348519)
Frankman
Gold Supporting Member
Frankman
Reg: 09-25-17
12-02-17 07:32 PM - Post#2716681
So I thought I had it all figured pot, a 500 siries power steering for my 55 chevy but every time I say that someone will ask why not a rack and pinion steering. So for those of you that have gone to power steering I'd like to hear the pros and cons on this issue.And I will continue to do some more research, Thank you in advance.
12-02-17 07:42 PM - Post#2716684
    In response to Frankman
Certainly r and p eliminates all linkage and sloppiness of the gear box set up. But the conversion and installation is more complex. The difference in my 51 with a power 93 Mustang Gt rack was dramatic compared to the basic 30's design that was oe. Your car had a much better steering then the 51, to begin with.
Edited by Shepherd on 12-02-17 07:44 PM. Reason for edit: No reason given.
Jalapeno
Jalapeno
Loc: The Republic of Texas
Reg: 04-30-00
12-03-17 06:40 AM - Post#2716716
There are quite a few choices today for power steering. Some require solving many problems to make them work well, like r&p, some are simple bolt on jobs, like the original linkage type PS, and some in between, like the 500 PS gear, and even electric power steering from EPAS.
The way your car is equipped now will eliminate some of those choices. For example, if you have a column shift manual transmission, you cannot install any PS gear including the 500 PS gear. EPAS electric power steering cannot be installed with ANY column shift transmission. R&P is difficult to install with BBC and some headers. The OEM linkage type PS is probably the most versatile system but the existing manual steering gear must be in good condition and adjusted properly to get the best performance out of this system.
Jalapeno
Frankman
Frankman
Reg: 09-25-17
12-03-17 11:42 AM - Post#2716744
    In response to Jalapeno
No my options aren't limited since My original plan was to put a 700R4 behind a zz6 engine, an Ididit coloum shift. All the frame is cleaned up and ready. I was going to just rework the front end and put a 500 series P/S box and I may still, I just have to decide which P/S I'm going with.
Bad56Sedan
Bad56Sedan
Loc: Pasadena, Texas
Reg: 04-29-04
12-05-17 07:05 PM - Post#2716994
500 box in '56 sedan
Pulley issues
Box is heavy, not easy to hold up and start bolts
Finding correct belt
Possible issues with an a/c car
Possible issues with certain headers
Pump mount bracket issues
Possible moving radiator forward
Mast jacket revamp
Rebuild mast jacket
Cut original steering shaft
Finding right parts
Car drives like a go cart
It looks good
I did it my self ........priceless
VC56S 2 door Sedan, 38 Years
Edited by Bad56Sedan on 12-05-17 07:18 PM. Reason for edit: No reason given.
Frankman
Frankman
Reg: 09-25-17
12-05-17 07:33 PM - Post#2716996
    In response to Bad56Sedan
Yeah I'm sure I'll run into some issues, that's why I'm going to do as much as I can while the frame is off. I just got the suspension off boy what a pain, going to shop around an see what it will cost to redo all the ball joints,bushings and all the rubber and weigh that against going with something new.
Frankman
Frankman
Reg: 09-25-17
12-05-17 07:36 PM - Post#2716998
By the way enlighten me what is the mast jacket.
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
12-05-17 08:15 PM - Post#2717004
It is the metal tube over the steering shaft, it needs to be shortened due to rag joint and split shaft,
It has the wires inside it for turn signals, horn
Edited by Bad56Sedan on 12-05-17 08:16 PM. Reason for edit: No reason given.
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
12-05-17 08:19 PM - Post#2717006
Shortened mast jackets are available at some of those after market boutiques
Edited by Bad56Sedan on 12-05-17 08:20 PM. Reason for edit: No reason given.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
12-05-17 08:25 PM - Post#2717008
Our 56 was already done when we bought it. Had the 500 series CPP box installed. It drives good. Even with the big steering wheel it easy to turn stopped.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Frankman
Frankman
Reg: 09-25-17
12-05-17 08:44 PM - Post#2717010
Oh ok I understand what your talking about, thanks for the clarification.
12-05-17 09:06 PM - Post#2717011
    In response to Andy4639
"Even with the big steering wheel..."
Big steering wheel decreases steering effort, doesn't increase it.
Back to the problem at hand, a CPP500 or Borgeson 670 box is far easier to do than a rack and pinion. All of them require a power steering pump, so that problem is the same for all. R&P also requires changes to the steering column, though the length requirement is not as precise.
If you are keeping the stock front suspension, a p/s steering box is far easier than R&P, as R&P usually has difficulties with routing the steering shaft past the exhaust. Not that it can't be done, it's just easier with fewer compromises.
The other half of R&P is that it's good to use with a frame/suspension designed for it, like a C4 front clip, aftermarket frame/suspension etc.
Frankman
Frankman
Reg: 09-25-17
12-06-17 07:24 AM - Post#2717044
    In response to Rick_L
I don't know what a C4 front clip is, but you just said exactly what I have been thinking. So at this time I'm still thinking the 500 series power steering box an I'd did it steering coloum and the stock suspension reworked. I will listen for more options before my final decision .
12-06-17 11:22 AM - Post#2717068
  • Frankman Said:
I don't know what a C4 front clip is.....
4th gen Corvette (1984-96). This is the first significant suspension change since 1963.
Frankman
Frankman
Reg: 09-25-17
12-06-17 12:33 PM - Post#2717084
Ok thank you.
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
12-06-17 03:32 PM - Post#2717097
But this bolt in took me a few months to do.
As reported when I got it done, it is one finger steering with the 1970's little steering wheel, and it is kick ssa.
And I have the 13" Cal Chrome ? Kinda steering wheel.
As Jalepeno said, it steers like a go cart.
Poor mans bearing........waste of time.
Attachment: image.jpg (74.83 KB) 13 View(s)
Edited by Bad56Sedan on 12-06-17 03:36 PM. Reason for edit: No reason given.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
12-06-17 05:03 PM - Post#2717105
Yes I understand this, What I was trying to get him to understand it is very easy to turn the wheels even at a standstill.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Frankman
Frankman
Reg: 09-25-17
12-06-17 08:11 PM - Post#2717128
Understood I'm sure no matter which way I go it's going to be a Hugh improvement. Thanks for the response.
Jalapeno
Jalapeno
Reg: 04-30-00
12-10-17 06:56 PM - Post#2717512
Frankman, when rebuilding your front end, regardless of the PS choice you make, get new upper a-arms that have an extra 5 degrees caster built in. Additional caster will really help tracking. Cost is about $200 for the pair. They are fully assembled with bushings, shafts and ball joints, ready to install.
You can rebuild your original a-arms with new bushings and ball joints but you'll still have the stock 0 degrees caster at most. With the cost of the parts and having the bushings installed, it's about the same $.
Jalapeno
Frankman
Frankman
Reg: 09-25-17
12-10-17 09:45 PM - Post#2717532
Ok I was thinking about ordering the complete front end suspension rebuild kit, but I think the control arm is probably like the original.I'll have to ask.thanks for the info, I'm also thinking about ordering the springs that will drop the front end an inch and a half or so.Boy I'm sure glad you posted this today as I was going to order the kit tomorrow. Sometimes I feel like I'm trying to move to fast before I get enough info, maybe I need to slow down and allow the info to come in.Thank you I appreciate the help.
Jalapeno
Jalapeno
Reg: 04-30-00
12-11-17 06:19 PM - Post#2717616
  • Frankman Said:
Boy I'm sure glad you posted this today as I was going to order the kit tomorrow. Sometimes I feel like I'm trying to move too fast before I get enough info, maybe I need to slow down and allow the info to come in.
You have the right idea, take a little while to digest the good advice you are getting. You will be so much happier when you make informed choices.
Jalapeno
Frankman
Frankman
Reg: 09-25-17
12-11-17 07:51 PM - Post#2717632
Thank you JalapeƱo I will try to listen closly to the advice I receive, thank you for your response.
Frankman
Frankman
Reg: 09-25-17
12-11-17 08:52 PM - Post#2717637
Ok Jalapeno been reading up on front end alignments to get some understanding. So if I were to buy the upper control arm with 5 degree positive caster, can it be adjusted from 0-5 or does it stay a 5 degrees positive.And I imagine alignment tech's are used to dealing with this issue.
12-12-17 07:35 PM - Post#2717741
Adjustment range with the shims is only maybe +/- 1.5 degrees or so .
In other words you are going to have 3.5 - 6.5 degrees of caster.
Not a big deal unless you install these control arms with a manual steering setup, because steering effort will be a bunch.
Bruces 57
Reg: 01-03-07
12-20-17 08:23 AM - Post#2718543
Hello;
here is what I did to my 57!!!
500 steering box
Poormans steering upgrade (before the 500)
upper and lower tubular control arms (before the 500)
Pre cut steering column for this upgrade (have shift connected)
My car has the power steering pump, ac compressor and alternator, all pulleys worked just fine!
The first time I drove it (BTW I have the repo small steering wheel) I was absolutely amazed that I could spin donuts with such a heavy car! Absolutely Astounding! Borderline magic trick!!!!!
Bruce
Frankman
Frankman
Reg: 09-25-17
12-20-17 08:34 PM - Post#2718625
    In response to Bruces 57
Ok so I ordered the whole front end suspension rebuild kit and also ordered the upper control arm with the 5 degree positive caster, it will be a while till it's on the road but I fully expect that it will work good, with the 500 series steering box and an Ididit steering coloum. Anyway we'll see.I haven't decided on the steering wheel yet.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
12-21-17 05:58 AM - Post#2718637
With a tilt wheel the factory hugh wheel will be ok I think. You can adjust it so you can slide in under it. I wished I had tilt in our 56.
I want to buy one of the smaller diameter wheels for ours but pop ant wanting to. It's all I can do to get under it. At 5-9 210 it's tight!
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
55Sedan210
Reg: 12-21-17
12-21-17 07:23 AM - Post#2718644
Going to be doing the power steering upgrade on a 55 sedan. Do I need to replace the pitman & drag link? Original manual car.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
12-21-17 07:55 AM - Post#2718645
The new steering 'box' has a ratio of something like 14:1 (may be 16:1?). The original power steering box is 24:1 (I think 28:1 w/manual steering). Little rotations of the OEM steering wheel (big) result in 'larger' angles of component rotation if used with the 14:1 ratio box. Not at all a show stopper, but if one keeps the OEM steering wheel when converting to the integral power steering box, the steering is more sensitive to minor rotations of the steering wheel. Should just take a little time to get used to.
Pete
Frankman
Frankman
Reg: 09-25-17
12-21-17 06:02 PM - Post#2718713
    In response to japete92
Ok thanks it sounds like I better consider a smaller steering wheel.
Execution time: 0.304 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:05 PM
