Username Post: 08 Yukon denali        (Topic#348517)
scotty40
Reg: 07-10-08
12-02-17 03:45 PM - Post#2716660
Any notorious problems with these? It has the 6.2 L gas motor fully loaded but has 225K miles.
Appreciate any input. Thanks
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
12-02-17 07:42 PM - Post#2716683
    In response to scotty40
just exhaust manifold studs.
Some have issue with oil pressure but have only ran into a few that had that issue.
Front hub assemblies.
rear brakes if it has the dual brake setup.
Fuel pump harness.
not sure if they still had the knock sensor issue.
Brake light switch are common.
All off the top of my head
Old School GM fan FOREVER
Edited by rockfangd on 12-02-17 07:45 PM. Reason for edit: No reason given.
scotty40
Reg: 07-10-08
12-03-17 12:45 PM - Post#2716749
    In response to rockfangd
On the brakes are you referring to caliper issues?
Corrosion in fuel pump harness?
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
12-03-17 03:37 PM - Post#2716763
no the parking brake setup.
The harness does not corrode it gets hot and melts
Execution time: 0.24 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:26 AM
