Username Post: 89 k2500 4x4 5.7 heater issues        (Topic#348515)
Karie_ann1977
Reg: 09-25-17
12-02-17 01:42 PM - Post#2716645
My heater only blows cold air. The heater core is not restricted. The intake coming from the heater core is restricted. Any ideas or suggestions greatly appreciated!
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
12-02-17 02:26 PM - Post#2716652
    In response to Karie_ann1977
Not good, I've gone through partial winters that way. Not fun. Usually do to a leaking/bad core that I had to bypass.
You're saying it gets hot?
Are you saying the air is restricted from getting to the heater core? If so, it sounds like it's a blend door problem. That's not something I've had to deal with, so others will be better help to you.
99 K3500 RCLB
Karie_ann1977
Reg: 09-25-17
12-02-17 02:36 PM - Post#2716654
    In response to 454cid
There are 2 hoses one goes between the heater core and intake and the other between heatter core and the radiator neither gets hot
Edited by Karie_ann1977 on 12-02-17 02:38 PM. Reason for edit: No reason given.
12-02-17 03:10 PM - Post#2716659
If neither hose gets hot you aren't getting any flow. Disconnect both hoses at the engine end and blow through either one. DO NOT use compressed air or else you may rupture the core. If you can't blow through, you may have to open up the heater for a look. I am suspecting a control valve in series with the core which is stuck closed, but I don't KNOW this to be the case for sure. Someone else here might suggest a better way to find out.
Karie_ann1977
Reg: 09-25-17
12-02-17 03:48 PM - Post#2716661
I was able to blow air through and I flushed with garden hose to be sure it was clear. Thanks for your help maybe someone else will know something we are missing.
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
12-02-17 05:54 PM - Post#2716676
  • raycow Said:
...I am suspecting a control valve in series with the core which is stuck closed...
GMT-400's don't normally control coolant flow through the heater core. I think it's normally SUV's that actually uses them, but maybe crew cabs, do as well. Rockauto lists one for my truck, I believe, but it's never had one, and I bought it with only 6K miles. Some people also add them..... been wanting to do it for years, but never have.
99 K3500 RCLB
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
12-02-17 06:01 PM - Post#2716678
Well that's a good sign.
Has this just started happening, and is this the first you've needed the heater this season?
What's the coolant temperature gage doing? Low temperature and the air won't be hot at all, and low level will mean it will be intermittently warm/hot and the gage needle will rise quickly and then drop suddenly.
99 K3500 RCLB
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
12-02-17 07:40 PM - Post#2716682
is your coolant full?
Has it been purged?
If both are good then take off the line from the intake at the heatercore and check for flow.
Also inspect the pot metal fitting at the intake. If still present.
find out where the return line goes.
It will either go to the waterpump or the radiator on the passenger side at the top
Old School GM fan FOREVER
Chevytech
Chevytech
Reg: 04-25-04
12-03-17 07:29 AM - Post#2716721
    In response to rockfangd
That is the next place I would look.
The hole in the bottom of the fitting could be plugged.
rain_man_rich
Loc: Grants Pass, OR
Reg: 02-09-14
12-03-17 07:45 PM - Post#2716798
    In response to Chevytech
You could, but please be careful, take the top hose off the connection at the firewall (I believe this is the inlet to the heater core). Then start the truck up to see if it pumps water through the hose. Again, please be careful.
Mjricha
Infrequent Contributer
Reg: 11-30-17
12-04-17 02:10 PM - Post#2716870
    In response to rain_man_rich
I had an old f150 this happened to. Turns out someone had put stop leak in it and the inlet INTO the radiator from the heater core was clogged from rust build up and stop leak. I poked out the clog and flushed the radiator and that took care of the problem.
Execution time: 0.28 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:19 AM
