Username Post: Liftgate: Replace Struts        (Topic#348506)
Jim Mee
Reg: 12-01-17
12-01-17 05:42 PM - Post#2716590
FYI
What you need to know Nomad liftgate:
Replaces lift supports with a 10 mm ball socket rod connector, and a 10 mm ball socket tube connector.
Replaces lift supports with extended length between 16.5 In. and 17.5 In.
Replaces lift supports with a force between 45 lbs and 55 lbs
Note: All Auto part stores sell them.
The ones I got were form Auto Zone pt. #D95779 (Black) not stainless steel. They work great.
Question:
Who did u buy the kit from? Our kits have 40#s the others on the market are 35# which tend to go out on people. I wouldn’t use a 50-55# on a nomad liftgate. We have used that rating on the brass gates and they are 10 pounds heavier than the potmetal frames. 40 does the trick, not too much where it pushes the gate up during adjustment and not too little.
So I’m guessing you bought the kit and they went out on you. So u had the 35#s
Answer:
I bought my kit in 2007 just now put them on. No numbers on struts and don't know #s. All I know when I put them on they would not hold liftgate up. I'm sure 40#s is good advice. Thanks for input.
nomads
Execution time: 0.221 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:40 PM
