Username Post: alt/voltmeter ?        (Topic#348491)
rod
Loc: kingman,az
Reg: 04-29-00
11-30-17 02:42 PM - Post#2716431
my 82 year old friend has an 2016 chevy truck [like a C-1500 or whatever they # them as now] anyway, after driving about 30 miles the volt meter goes way down after while it goes back to 14 V. he is worried.
I wonder if the computer is shutting the alt. off to save gas, and then turning it back on when the bat. requires a boost. old time generators worked like this. whereas most alts. charge all the time, and use HP.
am I right or wrong? is the truck OK or not?
Thanks Rod in AZ
2plus2
Loc: Mission,BC
Reg: 02-03-05
11-30-17 04:24 PM - Post#2716442
    In response to rod
Normal
GM started doing this ~10 years ago
69 Canadian Pontiac 2+2
elcamino
elcamino
Reg: 03-30-00
12-03-17 02:32 PM - Post#2716757
    In response to rod
Read the owner's manual page 138.
Subject: Information On Voltmeter Gauge Fluctuation Due To Regulated Voltage Control System And Concerns About Camper/Trailer Battery Charging
Models: Cadillac Escalade Models
Chevrolet Avalanche, Silverado, Silverado Classic, Suburban, Tahoe
GMC Sierra, Sierra Classic, Yukon Models
Voltmeter Fluctuation Condition:
Some customers may comment that the voltmeter is fluctuating between 12 and 14 volts on their full size pickup or utility vehicle. Starting with the 2005 model year, light duty full size pickups and utilities are equipped with a new Regulated Voltage Control (RVC) system. This system reduces the targeted output of the generator to 12.6-13.1 volts when in "Fuel Economy Mode" to improve fuel economy. The generator may exit "Fuel Economy Mode" if additional voltage is required. This will cause the voltmeter to fluctuate between 12 and 14 volts as opposed to non-regulated systems that usually maintain a more consistent reading of 14 volts. This fluctuation with the RVC system is normal system operation and NO repairs should be attempted.
2016 Polaris RZR 900 EPS
Execution time: 0.165 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:33 PM
