Username Post: Steering wheel Column shorten        (Topic#348482)
NathanS
NathanS
Reg: 05-21-17
11-30-17 10:10 AM - Post#2716393
ANyone done this yet? I am looking to shorten the steering column and make more room to move the seat back and forth.
11-30-17 11:41 PM - Post#2716492
    In response to NathanS
Are you planning to keep the stock steering gear? If yes, this is a first for me.
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
12-01-17 01:18 AM - Post#2716497
The Tri-Five Chevrolet vendors sell a set of plates that are used with the stock bench seat, but reposition the tracks further back to afford more room. Maybe make something similar for your seat? I am Butch/56sedandelivery.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
12-01-17 03:03 AM - Post#2716502
Hi Nathan, welcome. How tall are you?. Yes it is possible to do what you suggest, but it will probably cost a lot of beer vouchers.
Normally the steering column change out is done with front suspension conversions, or if folk want a tilt column.
Cheers Kiwi
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
12-01-17 12:49 PM - Post#2716557
Years ago i shortened mine at the top, Cut the shaft below the splines and took out 3", I machined a collar to slide over both pieces and welded it in place.
The main tube was shortened also. The column is still on a shelf in the shop today.
I would only advise this for someone with machine shop experience and that is an expert welder.
VANDENPLAS
VANDENPLAS
Loc: ontario canada
Reg: 07-29-09
12-02-17 05:23 AM - Post#2716624
    In response to cbmkr56
I know the stock coloumn s have been shortened when changing out steering boxes
Look into astrovan steering box swap
Or do as has been said and move your seat back some
Execution time: 1.967 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:21 AM
