Username Post: Exchangeability?        (Topic#348479)
49 delivery glen
Loc: Pennsylvania
Reg: 10-10-17
11-30-17 08:39 AM - Post#2716387
What year's of chevy parts will match a 49 delivery?
49 Chevrolet delivery.
11-30-17 09:33 AM - Post#2716397
    In response to 49 delivery glen
Engines and transmissions and front suspensions are bolt-ins from '49 to '54. Steering parts will swap into a '49 S.D.
The rear doors of S.D.'s from '49 to '54 are interchangeable I think. Front doors are not a bolt in between cars and S.D.'s. WIndshields are swappable. Vent windows I think are, but door glass as I recall isn't. I'm not 100% sure about the door glass swapability tho. Dashes are the same between S.D.'s and pass cars.
49 delivery glen
Loc: Pennsylvania
Reg: 10-10-17
11-30-17 09:48 AM - Post#2716401
What about the hood and fenders. I recently purchased a 49 delivery for $200 it's completely there except for the rusted out parts. I found a14GK J 101096 #. Mine is a a 14
49 delivery glen
Loc: Pennsylvania
Reg: 10-10-17
11-30-17 09:52 AM - Post#2716403
14GJ J 31293.And I was wondering if the hood and fenders were the same.
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
11-30-17 10:05 AM - Post#2716404
49 front clip is the same as 49-50 Pass cars, The hoods are the same 49-52. 51-52 had a different splash pan front fenders and grill.
53-54 was totally different.
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
11-30-17 10:08 AM - Post#2716405
The top rear of the front doors are different and change the glass as they are rounded instead of square.
49 delivery glen
Loc: Pennsylvania
Reg: 10-10-17
11-30-17 10:33 AM - Post#2716409
    In response to cbmkr56
Thanks very much for the information! I'll be off to the junk yard to salvage all the parts I can.
Thanks a bunch,
G.A.M.
eplantage
Loc: Southern MN
Reg: 03-15-04
11-30-17 11:25 AM - Post#2716416
Front doors from a 4 door will work if you modify the rounded corners as mentioned earlier, 49-52 only. Stainless trim varies from year to year. Belt line trim is the same 49-52, 53-54 has a fluted center on this trim.
Age: 63 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
49 delivery glen
Loc: Pennsylvania
Reg: 10-10-17
11-30-17 03:45 PM - Post#2716443
    In response to eplantage
I luckily have all of the trim,but it's good to know what will fit in case I mess some up. Thanks so much for the information.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
12-01-17 01:53 AM - Post#2716500
Hi Glen if you want to keep it near stock then there were some quite useful improvements between 49-54.
53 powerglide and all 54 on had full pressure oiling, not dipper, and can be adapted to your situation. Also are 235 and a few 261's
52 and on had Bendix brakes which are much better and adapt quite easily. The 53-4 trans are better and the later steering boxes had bearings.
If you upgrade the engine to a later 235 it will appreciate if you swap out the manual 4.1:1 torque tube for the 3.55:1 from a powerglide car.
From memory the 53-4 front uprights sit the car lower
These cars also respond very well to electronic ignition and conversion to 12V.
Details of how to do all this are on the forum.
The best advice is to think out your plan for what you want and need from the vehicle and stick to it.
Cheers Kiwi
Edited by Bel Air kiwi on 12-01-17 01:55 AM. Reason for edit: No reason given.
Execution time: 0.175 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:15 AM
