Username Post: Building supports        (Topic#348450)
Frankman
Gold Supporting Member
Frankman
Reg: 09-25-17
11-28-17 02:55 PM - Post#2716126
Ok so I got the body off of the frame now, I need some ideas on how to build something to support the body up high enough to work under nieth and be stable, keep in mind that it is a convertible.
Bluemeany
Bluemeany
Loc: Santa Clara, CA
Reg: 05-31-02
11-29-17 03:37 PM - Post#2716285
    In response to Frankman
Probably want to use a rotisserie. Definitely don't want to scraping and painting looking up.
Well worth the cost. You can probably buy a decent one used and sell it when you're done.
Here is an example:
57 Hardtop 302 & 3 Speed OD
93 Camaro Z28 Indy Pace Car
Frankman
Frankman
Reg: 09-25-17
11-29-17 09:51 PM - Post#2716338
    In response to Bluemeany
I had thought, about that but wasn't sure cause I had another friend that did a nomad on a rotisserie and he told me it was a pain to work with. Maybe it's the quality of the rotisserie, who knows. Any way thank you for the response I appreciate it.
Lee T
Reg: 07-05-12
11-30-17 01:46 AM - Post#2716353
They can be a pain if you don't get it balanced right, but depending on what you are doing, a body cart my work.
Edited by Lee T on 11-30-17 01:47 AM. Reason for edit: No reason given.
11-30-17 08:18 AM - Post#2716373
    In response to Lee T
As Lee said, a balanced rotisserie makes it easy to work on the underside. The one pictured looks to be way bottom heavy. I could rotate my 57, 360 degrees with one hand and it stayed in any position without locking it down. On my hardtop, the center of the pivot was 13 1/2" above the front and back body mounts.
CharlieC
CharlieC
Loc: Flower Mound, TX,
Reg: 03-27-02
01-09-18 03:30 PM - Post#2720589
Just remember if you use a rotisserie with your convertible (which I highly recommend if you take it all the way down) you have to build in supports between the cowl and the back of the body.
Here's a pic when I put my body back on the car. The bar you see went into the top door hinge mount and connected to the top mount and was also bolted to the floor.
Noticed that all the guys that replied had roofs...
Charlie
'74 K5 Blazer 4x4
'14 Ram 2500 Diesel MegaCab 4x4
Frankman
Frankman
Reg: 09-25-17
01-11-18 08:32 AM - Post#2720770
    In response to CharlieC
Hi Charlie thanks for your response, I ended up building a brace from the upper front door hinge to the door latch, it's not supported on the floor and it's up on saw horse's. I suppose it's not to late to weld onto the support and the floor. So did you do the body work while it was off of the frame.
CharlieC
CharlieC
Reg: 03-27-02
01-11-18 02:07 PM - Post#2720790
You want to do any/all panel replacing and filler work on the frame. Blasting, sanding, etc can be done off.
You don't have to have the floor connection, I did, just to.
Charlie
'74 K5 Blazer 4x4
Frankman
Frankman
Reg: 09-25-17
01-11-18 06:25 PM - Post#2720814
Ok thanks.
Execution time: 0.307 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:16 AM
