Username Post: 97 k1500 5.7 timing chain        (Topic#348435)
mattwehrwein
Loc: wisconsin
Reg: 03-18-09
11-28-17 02:17 AM - Post#2716045
I'm about to put a new chain and sprockets into my 97 k1500 5.7.
Is there anything else I should replace while doing this? Any tips or advice? Engine has 460 thousand on it.
I'm also replacing the cam position sensor.
Thank you
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
11-28-17 05:59 AM - Post#2716059
    In response to mattwehrwein
The plastic timing cover should always be replaced when removed.
Bowtie_Guy454
Loc: Kentucky
Reg: 11-15-17
11-28-17 12:14 PM - Post#2716103
    In response to junkman104
Like junkman said do timing chain cover its really a one time use cover the gasket is made on it. Only $22 bucks from parts store. I would drop oil pan also and change oil pump too with that many miles but thats just me.
91 Chevy r3500 crewcab dually 454
96 chevy tahoe 5.7
93 chevy suburban 4x4 5.7
91 s10 blazer 350sbc
mattwehrwein
Loc: wisconsin
Reg: 03-18-09
11-28-17 10:35 PM - Post#2716221
I already have a timing cover, cloyes gears and chain, delco cam position sensor ordered from rock auto.
The truck has a pretty decent miss and will kill when idling every now and then. Sometimes is hard to start and lacks power.
Codes came up as random multiple missfire, cam shaft position sensor, and crankshaft position sensor.
All new plugs, cap and rotor. ( will be ordering an ac delco cap and rotor and possibly wire set due to my bad luck with duralast parts. I put fuel injectors in and a new pressure regulator.
This will be my first time putting a timing chain and gears on one of these trucks. I was hoping to just have to remove the water pump maybe radiator to do this job and avoid having to drop the oil pan.
mattwehrwein
Loc: wisconsin
Reg: 03-18-09
11-29-17 01:06 PM - Post#2716266
Would any of you recommend putting in a new delco distributor? Just wondering I have an AutoZone one in right now.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
11-29-17 01:12 PM - Post#2716267
Did you have the timing set with a scan tool?
Jeff
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
11-29-17 07:51 PM - Post#2716325
    In response to bowtie44s
I prefer to run delco caps and rotors only..
have had issues with cracking in even new caps, poor spacing in the points and in the rotor.
Both will cause issues
Old School GM fan FOREVER
mattwehrwein
Loc: wisconsin
Reg: 03-18-09
12-05-17 01:54 PM - Post#2716965
I got a cloyes timing set c-3092 an ac delco crank shaft position sensor a Felpro gasket set and new plastic timing cover with new bolts.
Everything just came in.
I've been having issues with bad 0-2 sensors even the delco ones for years. And been having issues with my cap and rotor for years getting corroded. Hopefully this will solve one of those issues as well.
mattwehrwein
Loc: wisconsin
Reg: 03-18-09
12-05-17 01:57 PM - Post#2716966
    In response to rockfangd
I think I'll order a new cap and rotor plus wire set all delco just wondering if I should grab a distributor as well? I suppose the distributor isn't to bad to throw in if you mark everything really good and turn the engine to top dead.
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
12-05-17 03:58 PM - Post#2716976
The distributor needs to be set with a scanner that shows timing offset.... or offset of something. I've read that a lot of the cheaper scanners/readers don't do it.
99 K3500 RCLB
mattwehrwein
Loc: wisconsin
Reg: 03-18-09
12-05-17 04:00 PM - Post#2716977
    In response to 454cid
Oh yeah I've dropped a couple In I just rent the scan tool at one of the auto stores I forget the entire procedure for setting it but believe I got directions off this forum.
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
12-05-17 04:04 PM - Post#2716979
Please post whatever the make and model of the scanner is, and where you got it from, for future reference by forum members.
99 K3500 RCLB
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
12-05-17 10:33 PM - Post#2717024
Yup. Cam retard angle. Set to 0+/-2 degrees at around 1200 rpm.
Greg
'00 Explorer XLT 4.0 V6 Auto
mattwehrwein
Loc: wisconsin
Reg: 03-18-09
12-06-17 04:16 PM - Post#2717101
It was at autozone I don't remember if it was an actron or different brand all I know is there were two different scanners one worked one didn't.
I know two different scanners that do work the snap on mt2500 and autoxray 6000.
mattwehrwein
Loc: wisconsin
Reg: 03-18-09
12-23-17 12:32 AM - Post#2718829
    In response to CowboyTrukr
I have the chain and gears are put in greased and torqued to specs. I had one more question before finishing her up.
Well I didn't have to lower the oil pan I kept it in place my question is where the cover meets the pan there is this thick line of silicone or rtv sealant. Should I pull that off of the pan and apply some new petmatex? Or is it suppose to be like that. It's probably 1/2 inch to 5/8ths thick and perfectly shaped.
Thank you
Steveo_supremo
Steveo_supremo
Loc: B.C Canada
Reg: 05-04-03
12-24-17 03:27 PM - Post#2718937
That is part of the oil pan gasket. It needs to stay there. You should have dropped the pan before removing the front cover. You can try to jury-rig it back together but it will most likely leak.
I'm not the pleasant pheasant plucker, I'm the pleasant pheasant plucker's son. I'm only presently plucking pheasants until the pleasant pheasant plucker comes.
mattwehrwein
Loc: wisconsin
Reg: 03-18-09
12-26-17 10:13 PM - Post#2719077
    In response to Steveo_supremo
It slipped right into place actually. Everything is hooked up I'm having an issue now with the crank sensor. The truck won't fire at all. It's just cranks no pops or any sighn of starting at all.
mattwehrwein
Loc: wisconsin
Reg: 03-18-09
01-27-18 06:03 AM - Post#2722322
Ok I took everything back apart again even lowered my oil pan this time to see what was causing the no start condition. I found rtv sealant was on the reluctor ring. Cleaned that off real good then popped my new crank sensor into place. I put everything back together and it took a lot to get the truck to start and was idling at 1000 rpms.
I loosened the distributor hold down bolt and turned the distributor counter clockwise as far as I could and it idles slightly above 500 now. When I hit the gas I can tell there is a hesitation though.
I know for a fact my sprockets are lined up right for the chain. Could it be a bad distributor? Should I pull the distributor and move it a tooth over so I can adjust it some more? I know I put this distributor in about 4 years ago but have had issues with hard starting for a while now and it's a cheap AutoZone distributor.
mattwehrwein
Loc: wisconsin
Reg: 03-18-09
01-27-18 06:34 AM - Post#2722323
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
01-27-18 07:22 AM - Post#2722328
You don't set idle speed with timing. You're probably idling at 60° BTDC. You will break a piston. Set the timing with a timing light and fix the IAC.
EDIT: I just noticed it's a 97. You have to set the timing with a scan tool.
Jeff
Edited by bowtie44s on 01-27-18 07:25 AM. Reason for edit: No reason given.
Execution time: 0.467 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:54 PM
