Username Post: how to wire dome light and door switches        (Topic#348428)
54chevybuff
Loc: Tuttle, OK
Reg: 01-18-12
11-27-17 07:34 PM - Post#2716000
how do you wire dome light and door switches? Which direction does the dome light base mount? switch towards dash or towards rear of car?
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
11-27-17 07:56 PM - Post#2716006
    In response to 54chevybuff
If you have a shop manual, I believe wiring to the dome light is shown...at least how the connections are made. The photo below should answer the question I quoted above.
Attachment: 1952_Deluxe_2_Door_20.jpg (271.17 KB) 11 View(s)
1951 Fleetline
54chevybuff
Loc: Tuttle, OK
Reg: 01-18-12
11-27-17 08:09 PM - Post#2716011
    In response to RAM_51
thanks!
53sd
Reg: 12-08-08
11-27-17 09:29 PM - Post#2716026
The dome light powers up from the head light switch.A good pic in the manual,electrical system 12-46 fig 62.Usally a orange wire.
The switch on the dome light grounds [completes] the circuit.
The door switches are also grounding the circuit,usually white wire,back to the switch on the dome light.Also be aware that the bulb in the dome light should have 2 terminals on the base,not grounded to the case/side.
Execution time: 1.19 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:58 PM
