Username Post: lifter tick only at startup        (Topic#348426)
john_johnson
Loc: Chattanooga, TN
Reg: 08-31-07
11-27-17 06:11 PM - Post#2715995
Hey all
Is it normal for my newly rebuilt stock specs 235 6 cyl daily driver’s lifters to tick for 30 seconds after overnight sitting?
Once they pump up the tick goes away.
Wondering if something needs done...adjust, replace, etc?
"That's all I have to say about that!"
Bluemeany
Bluemeany
Loc: Santa Clara, CA
Reg: 05-31-02
11-29-17 03:23 PM - Post#2716298
    In response to john_johnson
The noise you are hearing is in the valve train. You probably have valve improperly adjusted. With a cold engine, remove the valve cover. Get a two foot piece of garden hose to use as a stethoscope.
Have someone start the car and using the hose, identify the noisy rocker. Adjust the valve per manufacturer recommendation. For a temporary fix, you can try Motor Honey. Motor Honey works by improving oil viscosity. Motor Honey coats engine parts as well as quiets noisy engines.
57 Hardtop 302 & 3 Speed stick w/OD;
93 Camaro Indy Pace Car
11-29-17 07:57 PM - Post#2716332
If he ticking goes away after 30 seconds, I would leave the valves alone. With the engine stopped, any lifters which are under open valves will leak down. That's what is causing the ticking noise when you start the engine. The lifters fill back up once they get oil pressure and then the ticking stops.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
11-29-17 08:27 PM - Post#2716337
This is a rather common problem with todays replacement lifters.Don't worry aboyt it.
john_johnson
Reg: 08-31-07
12-03-17 04:28 PM - Post#2716781
    In response to Gene_Schneider
Thanks - im a little shy adjusting it - i knew the pumpup happens on hydraulic lifters - did NOT know that nowadays thats what you get - good info think ill leave them alone - FOR NOWV- only have 2000 - 3000 miles on this adjustment
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
12-04-17 08:23 AM - Post#2716835
Don't know what oil you are using but perhaps a higher viscosity may help.
Execution time: 0.219 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:09 PM
