Username Post: rear axle compatibility        (Topic#348423)
hobbypoor
Loc: Middle Georgia
Reg: 07-07-11
11-27-17 05:18 PM - Post#2715981
I have a 54 Belair with powerglide im redoing, and a 54 150 with a 3speed parts car. Speaking of the rear axles assembly...are they the same (outside of gear ratio) and are they interchangeable. if not, what are the differences?
54 Belair 4 door. Auto.
Put together a piece at a time....twice.
If GM had as hard a time finding parts as I do they would have been out of business years ago.
2blu52
2blu52
Reg: 03-12-02
11-27-17 05:27 PM - Post#2715983
    In response to hobbypoor
Should not be a problem.
THOMAS JEFFERSON
VANDENPLAS
VANDENPLAS
Loc: ontario canada
Reg: 07-29-09
11-27-17 07:58 PM - Post#2716018
    In response to 2blu52
Pretty sure other then the gear set everything else should be the same
11-30-17 08:00 AM - Post#2716380
    In response to VANDENPLAS
The axle HOUSINGS will interchange.
The 49-50 and 51-54 axle SHAFTS will interchange, BUUUUUUUUUUT, the pilot on the 49-50 shafts is a larger diameter than the pilot on 51-54 shafts. OK, for those of you who don't know what the pilot is, it's the round protrusion in the center of the wheel flange which fits into the hole in the center of the brake drum/wheel.
The 49-50 cars had Huck brakes and 51-54 had Bendix brakes. Thus, the brake backing plate, brake hardware and brake drums for 49-50 and 51-54 are different. The brake backing plates and hardware are interchangeable from one HOUSING to the other.
The rear backing plate (that bolts to the center of the axle housing) and differential case are interchangeable and all the axle shafts have the same splines.
Now, as an additional bit of information, the entire rearend of 53-55 Corvettes is basically a slightly modified 51-54 pass car rear. The MAIN difference is that the Corvettes had an open drive shaft/U-joint instead of a torque tube differential------------- - BUT, the differential guts are the same. Also, the pads that are welded onto the housing for the leaf springs are different. Soooooooooooooo, if you need axle shafts or brake parts for your 53-55 Vette, 51-54 pass car parts will fit.
11-30-17 10:48 AM - Post#2716410
We call that the wheel mounting hub here in upstate NY. Lol
12-03-17 08:47 AM - Post#2716736
yes, hence the term, hubcentric
Execution time: 0.165 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:40 AM
