Username Post: gas tank grounding        (Topic#348385)
66 Blu panel
Loc: B.C. Canada
Reg: 10-19-03
11-25-17 07:46 PM - Post#2715725
My understanding of how the fuel gauge works: Power is sent to the sender and the voltage is read at the gauge. The voltage is varied by the float.
Does the gas tank need to be grounded in order for the gauge to work?
11-26-17 04:45 AM - Post#2715754
    In response to 66 Blu panel
Yes, to complete the circuit.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
11-26-17 05:11 AM - Post#2715760
Hi BLU66, sort of. The power feed normally goes from the key to the gauge, sometimes it will have an interrupter to dampen the gauge and then the gauge is earthed through the sender. (This is called earth switching.)
This is safer, but it requires that the fuel tank is earthed to the chassis. If you put in a poly tank then you need an earth lead on the sender unit to the frame.
If your filler is not part of the tank, like on a lot of boats, then you should earth the filler neck to the tank and chassis as well. You do not want the friction of the fuel in the pipes while filling to cause static electricity.
If you have ever seen a small plane being refueled or a petrol tanker unload you will appreciate that this is good science, not urban legend.
Cheers Kiwi
Just in case you might need this...
Kiwi to American Translation:
Petrol = gasoline or fuel
Earth = ground
hope this helps!
Thanks for your help Clive! Good on ya mate!
--Hilandr
Edited by hilandr451 on 12-05-17 11:00 AM. Reason for edit: No reason given.
66 Blu panel
Loc: B.C. Canada
Reg: 10-19-03
11-26-17 09:36 AM - Post#2715785
    In response to Bel Air kiwi
Thanks for the replies. Filler neck is metal and screwed to the metal body, but, there is a thin layer of roofing tar between the two mating surfaces to prevent rust. I might have made the evening news:
OLD TRUCKS BURNS TO THE GROUND!
hilandr451
hilandr451
Loc: Anna Texas
Reg: 01-02-02
12-05-17 10:48 AM - Post#2716955
-The Hilander.
Silver 2017 Silverado 1500 double cab 2WD 5.3L
"Rattle can primer red" 1966 C20 Custom Camper 5.7L, 700 R4 trans 410 diff. front disc, p/s
Project Pics
66 Blu panel
Loc: B.C. Canada
Reg: 10-19-03
12-20-17 06:41 PM - Post#2718619
    In response to hilandr451
Thank you for the diagram.
hilandr451
hilandr451
Loc: Anna Texas
Reg: 01-02-02
12-21-17 10:46 AM - Post#2718668
why, you're welcome sir!
-The Hilander.
Project Pics
Execution time: 0.172 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:25 AM
