Username Post: Jumpy needle        (Topic#348370)
AmericaMade
Reg: 11-06-17
11-24-17 09:55 AM - Post#2715570
How do I fix this or start trouble shooting. and yes the needle looks weird because upon cleaning it snapped. So I super glued it back for the time being.
Seems the video plays but has a buffer if you havent the time to view, basically as I drive the speedometer needle bounces. Seems only when really accelerating or maintaining and higher speed
https://www.flickr.com/gp/141329848@N04/1X38 9Z
Edited by AmericaMade on 11-24-17 10:35 AM. Reason for edit: No reason given.
Senior Chevytalk Moderator
11-26-17 05:46 AM - Post#2715755
    In response to AmericaMade
The cable needs to be lubed or replaced. On rare occasions, the speedometer is bad. The problem is probably the cable. You can remove the cable. The inside turning part can be pulled out. A dab of light grease will help. Heavy thick grease will not work. If the grease is thick, the cable does not turn fast enough. My needle bounced around too. After using very light grease, the problem went away.
AmericaMade
Reg: 11-06-17
11-29-17 09:53 AM - Post#2716250
Thanks boss, appreciate it
Execution time: 0.193 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:59 AM
