LMC Truck
Username Post: Remote start        (Topic#348368)
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
11-24-17 07:43 AM - Post#2715561
I would like to add remote start to an 02 Suburban. I don't want after market. I would like to have exactly what GM would have installed in 2002. Is it possible? What all is needed?
Jeff
LMC Trucks
rockfangd
Loc: Utica ny
Reg: 04-13-10
11-24-17 09:25 AM - Post#2715572
    In response to bowtie44s
I dont think that was a option til 2005.
It is done between the BCM and RKE modules, and the other modules are tied in for feature controls.
What is your keyfobs part number?
Old School GM fan FOREVER
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
11-24-17 01:13 PM - Post#2715586
    In response to rockfangd
I think the 04 Malibu was the first GM vehicle to get that, so 05 for trucks sounds right.
99 K3500 RCLB
Edited by 454cid on 11-24-17 01:14 PM. Reason for edit: No reason given.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
11-24-17 06:15 PM - Post#2715609
I had a 2001 Impala with remote start so it was an option, maybe not in the trucks. I'm not sure what the key fob number is, it just has lock, unlock, and panic.
Jeff
rockfangd
Loc: Utica ny
Reg: 04-13-10
11-24-17 06:43 PM - Post#2715615
hmm.
I do see remotes listed that specify without remote start. but cannot locate remote with the option.
Did it have the start button at the top of the remote?
Like this
https://www.rockauto.com/info/327/22733524_Pri mary...
you could buy and program the remote and see if out of chance the option works. It can happen.
My research shows your 02 sub uses a 3 button remote but no remote start option. Will have to check some more
Looks like AP3 is the RPO code for remote start option but it only shows on cars, no trucks or subs til 05
Edited by rockfangd on 11-24-17 06:51 PM. Reason for edit: No reason given.
2plus2
Loc: Mission,BC
Reg: 02-03-05
11-24-17 07:10 PM - Post#2715620
Its more then buying the remotes
There is a kit with a keycode and new remotes
Gm has to program the pcm/bcm and last time I checked it was about $300 and you still got crappy range with the remotes
See if there is a t-harness for the truck and get a compustar with a good passlock bypass like a fortin
Alot better options for the remotes to
69 Canadian Pontiac 2+2
rockfangd
Loc: Utica ny
Reg: 04-13-10
11-24-17 08:27 PM - Post#2715628
    In response to 2plus2
that is what I would do also.
they are easier, cheaper, and better in many ways.
And they dont care if the check engine light is on
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
11-25-17 12:11 PM - Post#2715694
I think my 01 Impala fob looked like that, but it's been a while. My 08 Impala has a fob like that. The Suburban looks like that without the start or trunk button. I will check for that AP3 code. AP8 was another one I read.
If I do decide to go after market, is there one you would recommend? I don't want one with an alarm system and prefer one with the least wire cutting.
Jeff
rockfangd
Loc: Utica ny
Reg: 04-13-10
11-25-17 11:27 PM - Post#2715744
I have had excellent luck with Audiovox by prestige.
And as for the passlock bypass the FlashLogic works nicely.
Have run both for a extended period of time with no flaws.
very little to no glitches. You will want a bypass module that works with the remote start module.
Best way to go.
Another option is the xpresskit bypass module.
Stay away from Codealarm and any bypass module that uses a key.
You will only want a datalink type bypass
Edited by rockfangd on 11-25-17 11:32 PM. Reason for edit: No reason given.
LMC Trucks
Execution time: 0.192 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:50 AM
