Username Post: trans tunnel insulation        (Topic#348361)
hobbypoor
Loc: Middle Georgia
Reg: 07-07-11
11-23-17 06:01 PM - Post#2715515
Before I began my rebuild..I remember a insulation type material on the underside of the trans tunnel (Powerglide). It was oil saturated, torn, muddy and ratty. I got rid of it, but cant find a replacement. I wondered if some kind of insulation/sound deadening would work in place...suggestions on a replacement? Im almost read to put the trans/engine back in and feel something should be there.
54 Belair 4 door. Auto.
Put together a piece at a time....twice.
If GM had as hard a time finding parts as I do they would have been out of business years ago.
2blu52
2blu52
Reg: 03-12-02
11-23-17 07:35 PM - Post#2715525
    In response to hobbypoor
Have you checked the Chevy parts manual available at Old Car Manuals on line? There may be a hint there. On my 216 CI 3 spd manual I used under coating, sprayed several coats on and seemed to help.
THOMAS JEFFERSON
DanD1950
DanD1950
Loc: London Ont. Canada
Reg: 10-16-11
11-24-17 05:30 AM - Post#2715550
What I did was to stick dynamat to the underside of the tunnel.
Even thou it's a peel and stick, I secured it with this type of washered zip ties. Drilled 1/8" holes through the tunnel to pass the ties through.
The ties are actually sold as an aftermarket transmission cooler install kit.
Dan.
50 Styleline Deluxe, 2 Door Sedan, Was a 216cu", Three Speed Manual. She now has a 4.8Lt V8 LR4 injected engine, 4L60E 4 speed automatic, 10 bolt diff 342 gear with an Eaton C80 Locker
50_Fastback
50_Fastback
Loc: California Central Coast
Reg: 09-08-14
11-25-17 01:06 PM - Post#2715693
    In response to DanD1950
I went the extreme route and used an industrial insulation that is rated up to 1200 degrees from Pacor. To protect and insure that it didn't fall out I used a thin sheet of galvanized steel as an outer shell/shield.
I'm considering using it as a carpet pad in place of the stuff that comes glued to the back of the carpet.
The stuff is amazing. You can hold it in your hand and put a heat gun on the other side and not feel ANY heat penetration.
http://www.pacorinc.com/
Pyrogel® XT-E Thickness & Length: 5mm, 15 ft @ $270.00
Product total: $270.00
Shipping total: $69.52
Grand Total: $339.52
Can't wait to get my new 350 in and test it under harsh conditions.
Ron Starkey
Life's full of risks..........take one!
'50 Fleetline 350 SBC, TH350, Nova Rear end, Mustang II clip
2005 Harley Road Glide
Edited by 50_Fastback on 11-25-17 03:10 PM. Reason for edit: No reason given.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
11-26-17 05:40 AM - Post#2715752
    In response to 50_Fastback
Hi Guys, if you want to use Dynamat, it goes inside and will work well.
If you think you are getting a lot of transmission heat then you need a trans cooler. Excess heat is a huge Auto-transmission killer. It shouldn't be an issue in a road car or something is wrong.
You are far more likely to get exhaust heat particularly if you have it tucked it up tight for clearance. In the OE situation heat shields are used but for one of situations its far easier to just header wrap the underfloor pipes where it is an issue.
If I don't have header wrap on my 32 it burns the paint off the engines louvered side panels when sitting still.
Cheers Kiwi
Execution time: 0.203 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:45 AM
