Username Post: aligning torque converter and flexplate        (Topic#348360)
100fires
Infrequent Contributer
100fires
Loc: Santa Fe Springs, Ca
Reg: 04-15-15
11-23-17 04:40 PM - Post#2715502
First of all Happy Thanksgiving to all.
I read the manual and it said to align the X's on the converter and flexplate. I found the X on the converter but can't find it on the flexplate. Does anyone have a suggestion as to which side it is on and what to do if I can't find it.
Thank You
11-23-17 04:45 PM - Post#2715504
    In response to 100fires
What trans is this?
11-23-17 05:41 PM - Post#2715513
If you are talking about a Powerglide on a 235, I would expect the X to be on the rear face of the flexplate so you could see it when you bolt the PG to the adapter.
100fires
100fires
Reg: 04-15-15
11-23-17 10:52 PM - Post#2715535
That is where I was looking for it. It on a Flexplate from my 54 Powerglide since I am still running a 6 volt system. Any major concerns, if I do not line the X's up?
11-24-17 12:45 AM - Post#2715539
Maybe balance, but I honestly don't know for certain.
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
11-25-17 01:52 PM - Post#2715698
This is the flexplate from a 1951 PowerGlide. Maybe it will give you an idea. You can see the "BB" and also the place where metal was removed to bring it into balance. There is also the letter "D" on the ring gear that I think you can see once you enlarge the photo but not sure of its significance.
Attachment: 1951_PowerGlide_Flexplate.jpg (3.03 MB) 24 View(s)
1951 Fleetline
11-25-17 04:51 PM - Post#2715712
    In response to RAM_51
Well, that would seem to answer the question. The "X" is on the same side of the flexplate as the timing mark. That side of the flexplate would have to face forward when installed so you can time the engine.
100fires
100fires
Reg: 04-15-15
11-25-17 09:09 PM - Post#2715726
Thanks everyone. It makes a lot of sense to have it on the side that ace the engine instead of the converter. I will spin the engine and look for it on that side.
Airlifter
Airlifter
Reg: 06-07-15
11-26-17 06:27 AM - Post#2715762
I had the same concern when I had to attach the flex plate on my '54 transmission.
I seem to remember that either the bolt pattern or dowels would prevent the flex plate to be installed wrong. Also, you should be able to see the timing ball when the flex plate is installed.
Be sure to torque the bolts. Don't ask why I mention this.
Hope this helps.
1951 styline deluxe sport coupe w/54 engine & powerglide
Execution time: 0.295 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:43 AM
