Username Post: Cleaning Air cleaner        (Topic#348315)
AmericaMade
Reg: 11-06-17
11-20-17 07:48 PM - Post#2715142
This is the air cleaner on my truck presently.
Its a bit dirty what can I use the polish it up? Make it look new?
https://thmotorsports.com/i-1759823.aspx?utm_sourc...
Secondly what is the proper procedure to clean the filter itself?
Edited by AmericaMade on 11-20-17 07:52 PM. Reason for edit: No reason given.
Senior Chevytalk Moderator
11-21-17 05:15 AM - Post#2715159
    In response to AmericaMade
Use some mothers aluminum wheel cleaner. Use a soft brush or cloth. You can buy a sponge to put on a drill too.
What type of filter is it? Something like a K&N? Those require a special cleaner and fresh oil. Or is it stock paper? Stock paper will only last so long. Using compressed air, blow inside out. Don't tap it too hard. Just enough to dislodge large debri.
Execution time: 0.167 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:38 AM
