Username Post: doorlock keyfob        (Topic#348261)
Jack Crain
Loc: Wichita Falls, Texas
Reg: 07-24-11
11-18-17 07:21 AM - Post#2714835
Not sure if keyfob is correct name but the thing you unlock/lock doors with from a distance. It started working intermittently then finaly bit the dirt. I tried to unlock the drivers door with the key and had a very difficult time. I was afraid I might break the key. After playing with it for awhile, I got the door unlocked.
My question.... is thre a battery in the keyfob and if so, how do I change it and will I need to reset it for my truck or will just changing the battery do the trick?
It is a 2005 GMC Sierra
1946 Fleetmaster 4-dr Sedan with '57 235
Fenton Dual Exhaust and Intake
Dual Carter Webbers 2 barrel Carbs
HEI ignition
Front Disk Brake
T-5 Tranny
Edited by Jack Crain on 11-18-17 07:24 AM. Reason for edit: No reason given.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
11-18-17 05:07 PM - Post#2714885
    In response to Jack Crain
those fobs
were very problematic with the rubber membrane (the buttons)
The battery solder joints.
When the membranes start to fail it makes the buttons hard to press and intermittently work.
The case pops apart with a coin in the slot.
Once open it should take a CR2032 cap battery IIRC.
This is assuming you are referring to the oem fob
Old School GM fan FOREVER
Edited by rockfangd on 11-18-17 05:09 PM. Reason for edit: No reason given.
Jack Crain
Reg: 07-24-11
11-19-17 04:19 AM - Post#2714912
    In response to rockfangd
Thanks Rock. Yeah, it's the oem fob
HEI ignition
Front Disk Brake
T-5 Tranny
11-24-17 07:43 PM - Post#2715614
The directions to reset the fob after battery replacement should be molded inside the fob case.
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
11-25-17 12:56 AM - Post#2715639
Just changing the battery doesn't require reprogramming.... at least I've not done that. The only time I've done the reprogramming is when I bought a new fob from ebay. I looked online for instructions.
99 K3500 RCLB
11-25-17 11:16 AM - Post#2715683
    In response to 454cid
It's not reprogramming exactly, but when I changed the batteries in the ones for my truck they needed to be reset I guess would be the word for it. The instructions are molded into the inside of the fob case.
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
11-26-17 10:43 PM - Post#2715872
    In response to wagonman100
Press Unlock and Lock for 7 seconds, near car, to reset..... according to what's molded into mine. I don't recall ever having done that, Though. I guess I'll see if I need to do it, when I try to unlock my truck tomorrow.
99 K3500 RCLB
Jack Crain
Reg: 07-24-11
11-27-17 06:47 AM - Post#2715893
Thanks for the info.
HEI ignition
Front Disk Brake
T-5 Tranny
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
12-01-17 03:38 PM - Post#2716574
Just to update..... I did not have to reset my key fob after splitting it, and removing the battery.
99 K3500 RCLB
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
12-01-17 09:40 PM - Post#2716610
good.
Thanks for updating
Jack Crain
Reg: 07-24-11
12-03-17 05:26 AM - Post#2716706
Yeah, Same here. Just replaced the battery and it works. Thanks to all for the input.
HEI ignition
Front Disk Brake
T-5 Tranny
Execution time: 0.234 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:50 PM
