Username Post: Steering column mount        (Topic#348257)
postalcop
postalcop
Loc: MO
Reg: 06-01-12
11-17-17 07:30 PM - Post#2714810
Anybody have any pictures of how they mounted their factory steering column after doing a jag or mustang front end swap? I cut my shaft and am ready to connect it to my Jag rack and pinion but I'm looking at how to attach it to the firewall. I thought about welding a plate to the firewall, cutting a hole for the column and then tack welding it to the plate. That pretty much end up making it a permanent fixture to the car. Not a big deal to me since I don't see any reason for me to ever change it out.
53 Chevy 210
350 engine / 350 trans
3.42 chevy s-10 rear axle
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
11-17-17 10:22 PM - Post#2714820
    In response to postalcop
Hi Postalcop, It depends if you want to have a shifter still running down the column. If you don't then you can weld a tab on the column 90* out from the old pear-shape opening and slide the column in from the top and rotate it into position. I would put a support plate around the opening to tie this to.
Alternately if you put the weld to column plate on the inside then it's no big deal to remove the column by undoing your universal joint. Lift out from the inside (Spline or "D" shaft.)
Then just cut out a reinforcing plate for the engine side so its doubled and a bit tougher. I would be inclined to weld short bolts through by tacking the heads to the interior plate so you can do it on your own.
Also I would get a Frost plug and a greased battery terminal felt and glue it on the end of your column to keep it sealed and protecting the bearing.
Cheers Kiwi
Edited by Bel Air kiwi on 11-17-17 10:33 PM. Reason for edit: No reason given.
hpva
hpva
Loc: Kinderhook NY
Reg: 03-31-13
11-18-17 07:00 AM - Post#2714834
You can get a universal steering column floor mount from vendors such as Summit Racing,it bolts to the floor inside of the car where the steering shaft goes through the floor.That`s how I did mine in my 54.Also if you still want to use a column shifted 3 speed go to the Jim Meyer Racing website click on support then instructions and go to bottom of list and click on modifying a 39-54 Chevy steering column.
[URL=http://s275.photobucket.com/user/hpva53/media/Bel Air/Homers542014-03-27018 _zps7d64af95.jpg.html][IMG]http://i275.photobucket.com/albums/jj296/hpva53/B elAir/Homers542014-03-270 18_zps7d64af95.jpg[/IMG][/URL]
50hotrod
50hotrod
Reg: 07-25-11
11-18-17 07:56 AM - Post#2714837
    In response to hpva
I used this mount after covering the opening like you did.
https://www.speedwaymotors.com/Speedway-Universal-...
I had this mount but found the first one worked much better and easier to fit and remove if needed.
https://www.speedwaymotors.com/Ididit-2401300010-S...
People done gone put their Bible's away
postalcop
postalcop
Loc: MO
Reg: 06-01-12
11-18-17 08:37 AM - Post#2714839
    In response to 50hotrod
Thanks for the replies. I will not be using the column shifter. Thanks for posting the links 50hotrod, I did not know there were aftermarket options.
Kiwi, yes my dad made a cap to weld on the end of the column to protect the bearing.
53 Chevy 210
Edited by postalcop on 11-18-17 08:40 AM. Reason for edit: No reason given.
kiwi54chev
Reg: 04-08-17
11-18-17 10:41 AM - Post#2714846
We put a plate on the inside of the cab and then a cheaper version of this column mount on the outside in the engine bay.
http://www.kruzinkustoms.com/view/hot-rod-parts/st ...
Looks pretty tidy
postalcop
postalcop
Loc: MO
Reg: 06-01-12
11-27-17 07:27 PM - Post#2715998
    In response to kiwi54chev
So the link that kiwi sent gave me an idea.I figured there had to be a way to make something so I went to Home Depot looking for pipe. I knew the steering column was 1 3/4 inches so I got a hole saw that size and walked around the store. I ended up walking to the electrical aisle and found conduit labeled 1 1/2 inches but the hole saw fit inside, so I bought it.
I cut it in half. It was a very tight fit for the column so I used a die grinder on the inside so the column fit in it easier. I then fastened the column up the way it should be and welded the pipe in place.
I think it should work out well.
53 Chevy 210
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
11-28-17 07:10 PM - Post#2716192
Hi Postalcop, That will work fine, though you could have welded your inside shape direct to the column and bolted it through the firewall, with a plate on the outside. Both versions are removable from the inside, but yours is adjustable which could be a real benefit.
Cheers Kiwi
flatout
flatout
Loc: NW
Reg: 12-15-01
12-08-17 07:52 AM - Post#2717296
Here is what I did on my '51. I need to clean it up a little more and paint it before final assembly.
Cruzin Okie
Cruzin Okie
Loc: Jay, Oklahoma
Reg: 10-26-11
12-08-17 10:34 AM - Post#2717313
    In response to flatout
Hey, could I just bring my car out to you, and you could use mine as a test platform. You do good work!!
Johnnie
1950 styleline deluxe sports coupe, 350 cid, TH 400, nova rear end. Gen IV Vintage air. SOLD!
1953 210 4 Door, 235 with Powerglide. All original except for the 1954 hood bird.
John 3:16
flatout
flatout
Loc: NW
Reg: 12-15-01
12-08-17 02:36 PM - Post#2717330
    In response to Cruzin Okie
Thank you. I’m afraid it would take longer than you would want to wait.
hpva
hpva
Loc: Kinderhook NY
Reg: 03-31-13
12-08-17 03:46 PM - Post#2717333
That really came out nice.
12-08-17 04:19 PM - Post#2717336
    In response to hpva
Outstanding work!
postalcop
postalcop
Loc: MO
Reg: 06-01-12
12-10-17 08:09 AM - Post#2717473
Looks good. Quite a bit simpler than what I did. I'd had have probably done the same thing had I thought of it.
53 Chevy 210
flatout
flatout
Loc: NW
Reg: 12-15-01
12-10-17 12:43 PM - Post#2717490
Thanks. Yours will work well also.
Execution time: 0.207 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:42 AM
