Username Post: Alternator issues...I think.        (Topic#348256)
The Beaster
Reg: 11-11-17
11-17-17 07:03 PM - Post#2714806
Another problem for my old truck.
I suspect the alternator. Battery is fairly new. Has been dieing lately. With heavy use plowing today...the truck just died.
What is an easy test to comfirm it is a bad alternator?(alternator is quite old).
Also.how do I attach a pic to a post?
Senior Chevytalk Moderator
11-18-17 06:52 AM - Post#2714832
    In response to The Beaster
Use a voltmeter. What is the output at idle or above idle?
If you don’t have a voltmeter, use the lights. Turn on the inside cab light while running. Next, turn on the headlights. The inside light should dim for a bit then brighten up again. If it does not brighten up again, you can suspect low voltage and possiblely a bad alternator.
11-19-17 06:52 AM - Post#2714917
Attachment: beaster.jpg (269.46 KB) 7 View(s)
Introducing The Beaster!
11-20-17 06:12 AM - Post#2715046
How many miles on the 454? It will like the new module over points.
What's the wheel green stuff?
Is that a barn? Nice log setup.
farm rat
Reg: 09-13-16
11-20-17 10:41 AM - Post#2715082
Start the truck then unhook the battery. If the truck keeps running then the alt. is still working at least somewhat.
Execution time: 0.407 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:06 PM
