Username Post: ‘66 Chevy Truck Headlights        (Topic#348231)
Sparkywax
Sparkywax
Loc: Indiana
Reg: 10-31-10
11-16-17 05:26 AM - Post#2714600
What are your thoughts or recommendations for headlights on my ‘66 truck? The stock lights are just not too bright........ I don’t need super bright just a little better then I have Now.
1955 Belair 2dr
1955 Belair 4dr (parts car)
1957 Belair 2dr
1964 Impala SS
1966 Chevrolet Truck
1968 Chevrolet Truck
1968 Impala SS 396 (Survivor)
bobschevytrucks.com Ecklers
jktucker92
jktucker92
Reg: 02-05-17
11-16-17 09:15 AM - Post#2714625
    In response to Sparkywax
The problem may be with your truck, not the lamp. Dim headlights could mean a problem with the wiring somewhere. Check the connectors at the back of the lamps for corrosion and partially broken wiring. The wiring for the headlights also goes through the dimmer switch and light switch. If any of them has excess resistance, then the light can be dim. It's less common to have issues with those connectors, but it is possible, and the switches themselves can have excess resistance.
To check, turn on your headlights and measure the voltage at the connector at the back of the lamp. A good resource is below.
http://www.popularmechanics.com/cars/how-to/a4246/...
55 Shaker
Loc: north central IL.
Reg: 03-13-06
11-16-17 09:36 AM - Post#2714632
Here's another option, hope it helps.
http://madelectrical.com/electricaltech/bright er-h...
Brian
hilandr451
hilandr451
Loc: Anna Texas
Reg: 01-02-02
11-16-17 12:17 PM - Post#2714653
    In response to 55 Shaker
I installed relays for my High and Low beam circuits and wired them directly from the battery terminal at the horn relay. For the power circuit I used 14 gauge wire. That improved the brightness greatly. Then I installed Halogen replacement lamps.
-The Hilander.
Silver 2017 Silverado 1500 double cab 2WD 5.3L
"Rattle can primer red" 1966 C20 Custom Camper 5.7L, 700 R4 trans 410 diff. front disc, p/s
Project Pics
Sparkywax
Sparkywax
Loc: Indiana
Reg: 10-31-10
11-16-17 02:33 PM - Post#2714676
    In response to hilandr451
I will definitely check out the wiring. What lamps are you using?
1955 Belair 2dr
1957 Belair 2dr
1964 Impala SS
hilandr451
hilandr451
Loc: Anna Texas
Reg: 01-02-02
11-16-17 04:53 PM - Post#2714689
I bought the ones from LMC. they have a housing that fits just like the original sealed beam and a handy little socket in the back where the lamp screws into. I have blue lamps for it too but I have never installed them.
-The Hilander.
Project Pics
66 Blu panel
Loc: B.C. Canada
Reg: 10-19-03
11-20-17 11:42 PM - Post#2715154
    In response to jktucker92
L.E.D. lights are supposed to draw less power. Without fixing the lower power problem would they be a lot brighter than stock?
jktucker92
jktucker92
Reg: 02-05-17
11-21-17 07:52 AM - Post#2715179
    In response to 66 Blu panel
LED lights do draw a lot less power. Because of that, the voltage drop at the light will be less and it can mask some minor wiring issues. They should alleviate the need for relays and upgraded wiring, but I would still check the factory wiring for frayed wires at the connectors, especially at the back of the lights.
11-21-17 07:54 AM - Post#2715181
Yes, but a set of LED headlights that are actually useful instead of just gimmicky junk, will set you back quite a bit of coin. There's really only one company I would trust for this and that's TruckLite; Maxxima also offers one but I feel their quality is a little lacking. Both are well-known suppliers of LED (and traditional) lighting for fleet vehicles.
http://www.truck-lite.com/webapp/wcs/stores/ser vle...
The TruckLite examples for the 7" round are about $160-$170 each, but they're very bright, are DOT compliant, have a 3 year warranty...and should last practically forever.
http://www.maxxima.com/products/27/LED-Headl amps.h...
Maxxima offers a 5 year warranty but I feel it's an attempt to gain market share over TruckLite. I've had so-so results with other Maxxima LED products. They're OK; just not great. The 7" round LED headlight is priced near the same as the TruckLite offering.
hilandr451
hilandr451
Loc: Anna Texas
Reg: 01-02-02
11-21-17 04:26 PM - Post#2715235
    In response to someotherguy
Good stuff! thanks Richard!
Personally, I don't think I would go to LED head lights on my truck. I get the performance I need from the halogens and I'm upgrading the alternator anyway because I have an electric cooling fan and fuel pump so the difference in overall draw isn't consequential. I've already resized the feeder conductors to the headlights so everything is good design wise.
-The Hilander.
Project Pics
Sparkywax
Sparkywax
Loc: Indiana
Reg: 10-31-10
11-22-17 05:53 AM - Post#2715284
Thanks everyone. Great information.
1955 Belair 2dr
1957 Belair 2dr
1964 Impala SS
11-22-17 10:09 AM - Post#2715331
My gripe with them is they have such a funky look and I think would spoil the appearance of a 60-66 truck (or any classic truck for that matter.) I dig technology when it delivers on its promise, which frequently it does not...but in this case even a good product like these TruckLite LED's, I see them fitting in better on modern heavy equipment that still uses a big round headlight. When you put it on a classic, even one that is a resto-mod, it just looks...wrong...to me. I don't care for the replacement housings that let you pop in a modern halogen headlight capsule in the back, either.
55 Shaker
Reg: 03-13-06
11-22-17 10:34 AM - Post#2715335
I'm with Richard, they just wouldn't look right on our older cars and trucks.
Todd W. White
Todd W. White
Loc: Sapulpa, Oklahoma
Reg: 02-08-08
01-09-18 11:48 AM - Post#2720568
I upgraded the wiring, sockets, added relays, and upgraded to HID bulbs with Bosch lenses. They look almost stock, work fabulously, and I can see better than ever.
Here's a link to the thread on it:
NOTES:
1. The link to the picture of the Bosch lens assembly doesn't work. The Bosch # is 301 600 118, and you can look it up on eBay or Google.
2. I used 35W, 4300K Bi-Xenon bulbs. They are not that awful blue you see all the time these days. VERY white!
Execution time: 0.194 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:49 AM
