Username Post: Brake pedal        (Topic#348228)
Frankman
Gold Supporting Member
Frankman
Reg: 09-25-17
11-15-17 06:58 PM - Post#2714552
When changing from standered shift to automatic what kind of brake pedal are we using.
11-15-17 08:09 PM - Post#2714565
    In response to Frankman
Same one, the stock trifive auto trans brake pedal was the same as manual unless you had treadlevac power brakes. And the treadlevac pedal doesn't work with the typical aftermarket boosters or manual brakes.
If you really want a wide pedal like a later model would use for an automatic, Lokar has a wide bolt on pad that bolts to the stock pedal. Or you could do some cutting and welding on a stock brake pedal and use a stock pad from a later model.
Do you left foot brake like some do?
Frankman
Frankman
Reg: 09-25-17
11-15-17 08:55 PM - Post#2714572
    In response to Rick_L
Ya I was thinking of a wider pedal I'll check out that Lokar bolt on, thanks gives me something to think about.
Execution time: 0.43 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:27 AM
