Username Post: 98 Sierra 5.7 v8 head gaskets        (Topic#348211)
sobieski
Reg: 11-14-17
11-14-17 07:43 PM - Post#2714407
Hey everyone,
I’m half way through a head gasket and valve repair.
Stuck valve on cyl 6. Bent push rod.
I hear this is the place to be for expertise and advice.
The heads are on there Reaally good and loking for your input on how to “pry” (I use that term loosely) them off w/o messing anything up.
Thanks,
Sobieski
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
11-14-17 08:08 PM - Post#2714415
    In response to sobieski
You should be safe taking a wooden dowel, inserting into the intake port and gently lifting. The longer, the better.
Greg
'00 Explorer XLT 4.0 V6 Auto
sobieski
Reg: 11-14-17
11-15-17 05:33 AM - Post#2714446
    In response to CowboyTrukr
Thanks CT.
Also, I think the previous owner put some kind of stopleak in the cooling system.
Whats the best way to be sure the block cooling passages are fully flushed out?
jktucker92
jktucker92
Reg: 02-05-17
11-15-17 01:35 PM - Post#2714505
When taking off the heads, make sure you have all 17 bolts removed. This may sound obvious, but I've seen photos of heads that were pried off with bolts still in place. Sometimes one or more of the bolts outside the valve cover are missed, and sometimes the outside bolts inside the valve cover are missed because they are recessed lower than the others.
As for flushing the engine. Usually, that's done with the engine running, and you flush out the entire cooling system, not just the engine. Given that your engine is at least partially disassembled, that won't be practical. In order to drain the engine to allow you to flush the lower sections of the block, you'll need to remove the 1/4" pipe plugs at the bottom of the block. For TBI engines the knock sensor is in one of those holes on the passenger side, and I believe that's true of the Vortec motors as well. You can remove them and remove the water pump and flush it out with a hose until all the water coming out is clean. If you run water through too fast, water will make it up to the top of the block and leak out and some will end up in the oil pan. Just want to be careful not to let too much oil in there. In any case, you'll want fresh oil in the pan for startup.
You'll also want to use the hose to flush out the radiator and heater core.
sobieski
Reg: 11-14-17
11-15-17 05:04 PM - Post#2714530
    In response to jktucker92
Got it. Thanks much.
How do i flush ou the heater core?
sobieski
Reg: 11-14-17
11-15-17 07:22 PM - Post#2714558
Also, should the lifers slide right out or does that retaining bracket inside the valley need to come off first?
Thanks in advance - really appreciate the help.
Edited by sobieski on 11-15-17 07:22 PM. Reason for edit: No reason given.
sobieski
Reg: 11-14-17
11-18-17 06:00 AM - Post#2714828
FWIW there is a bracket that runs down the middle of the valley which holds down 8 “collars”. The 8 collars set/sit on top of each pair of lifters.
I wish I could post pictures on here.
stumppuller
stumppuller
Loc: Canada
Reg: 11-01-04
11-18-17 08:02 PM - Post#2714898
Take the center bracket out (just 3 bolts), and then the collars lift off. It's a good idea to mark them so everything goes back to the original location(but I don't believe it's too critical for the collars). Mark the bracket so you know which way is Fwd/Face up.
The lifters can still prove difficult to remove sometimes due to an accumulation of varnish on the lower portion, there is a tool available to help with this.
Attachment: ccrp_0710_03_z-hydraulic_roller_cams-87_small_block_engine.jpg (94.07 KB) 6 View(s)
Attachment: 414HZOczy-L.jpg (27.95 KB) 4 View(s)
-91 Sierra C2500, now K2500
-81 Chev K20
sobieski
Reg: 11-14-17
11-19-17 06:14 PM - Post#2714988
    In response to stumppuller
Excellent. Thank you Stumper.
Stay tuned.
sobieski
Reg: 11-14-17
11-19-17 06:15 PM - Post#2714989
PS
I hear that i should replace the lifers.
What say you?
stumppuller
stumppuller
Loc: Canada
Reg: 11-01-04
11-19-17 10:00 PM - Post#2715024
On a flat tappet cam, the lifters and cam are replaced as a set.
On a roller cam (what you have), the lifters can be re-used as long as they are in good condition.
Personally, I would replace the lifters in the positions that had bent rods.
-81 Chev K20
sobieski
Reg: 11-14-17
11-21-17 07:25 PM - Post#2715247
Maybe i should replace em all?
On inspection they looked ok.
A few little wear marks.
stumppuller
stumppuller
Loc: Canada
Reg: 11-01-04
11-26-17 08:51 PM - Post#2715860
There is no reason not to re-use roller lifters if they are in good shape.
It is only the one with the bent pushrod I would be concerned with. You don't want the internals of the lifter to be damaged or it could collapse. It's not destructive to the engine, just means you would have to go back in and replace it.
-81 Chev K20
Edited by stumppuller on 11-26-17 08:53 PM. Reason for edit: No reason given.
sobieski
Reg: 11-14-17
12-17-17 07:27 AM - Post#2718245
As I prepare to put this thing back together, any advice on valve adjustments?
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
12-17-17 08:18 AM - Post#2718248
Do not soak the lifters. Cover them with assembly lube and put them in. Start at #1 cylinder TDC compression stroke and adjust both rockers to half turn past zero lash. Just go by the firing order. Roll the crank 90° and do number 8 then 4-3-6-5-7-2. Prime the oil pump until you have good pressure on the gauge, put the distributor in and fire it up.
Jeff
Execution time: 0.222 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:39 AM
