Username Post: Can I please get some help?        (Topic#348209)
396ss 4spd
Reg: 11-02-17
11-14-17 05:36 PM - Post#2714392
Can someone tell me if I'm missing something besides the filter and canister? Link below in
Oil cavity album
https://photos.shutterfly.com/album/120184877846
65 SS
1965 ss 396 4spd
Ermine White, Red interior
bigred65
bigred65
Loc: Kenmore WA
Reg: 03-18-13
11-14-17 05:53 PM - Post#2714396
    In response to 396ss 4spd
I can't see your photos. Sorry.
Brandon
1965 Impala SS 396 4spd
1966 Impala SS convert 4spd
1973 Corvette 4spd
1973 Firebird Formula 4spd
1959 Corvette FI 4spd will restore it someday!!!
396ss 4spd
Reg: 11-02-17
11-14-17 06:28 PM - Post#2714405
    In response to bigred65
Well my photo is identical to this one. Hopefully this link works.
65 SS
1965 ss 396 4spd
jktucker92
jktucker92
Reg: 02-05-17
11-15-17 07:18 AM - Post#2714461
You need the canister, filter, and the oil filter bypass valve. Link below has a good photo from Classic Industries (and you can purchase it there if you don't have one.)
https://www.classicindustries.com/product/1964/che...
396ss 4spd
Reg: 11-02-17
11-15-17 02:47 PM - Post#2714523
    In response to jktucker92
Thank you jktucker92, that's probably why my canister spewed a few quarts of oil through the canister?
65 SS
1965 ss 396 4spd
jktucker92
jktucker92
Reg: 02-05-17
11-15-17 03:45 PM - Post#2714526
The bypass valve is there to allow oil to bypass the filter if the filter is plugged. The other reason for the bypass valve is it traps the o-ring that is used to seal the canister to the block. New o-rings are provided with new filters. They can be difficult to remove when replacing the filter, but they must be replaced to prevent leaks. Without the bypass valve, the o-ring wouldn't stay in place and there would probably be a huge leak.
396ss 4spd
Reg: 11-02-17
11-16-17 03:54 PM - Post#2714690
Thank you jktucker92: I have it on order!
Thank you
65 SS
1965 ss 396 4spd
"14th Year" Platinum Supporting Member & Moderator
11-16-17 06:34 PM - Post#2714707
Here's the more comprehensive article in the Reference Area:
http://toms427impala.info/CT/DocPeteOilAdapter .pdf
396ss 4spd
Reg: 11-02-17
11-17-17 05:52 AM - Post#2714755
    In response to 427SS65
Thanks Tom, this is a great write up on the different styles of landing pads on the pre 68 blocks. After my oil mishap a lot of people were telling me to convert it to the spin on filter style. But my gut instincts were telling me that it wouldn't work all along, and this write up just confirmed it! Great info! Thanks again..
65 SS
1965 ss 396 4spd
11-17-17 10:28 AM - Post#2714774
You're welcome! Docpete supplied the info and pictures for that. I put that info into a document and put it on my server.
The old cannisters are a pain when changing the oil. My 427 is a newer block so it has the machined area for the spin-on filter. I take advantage of that with a two quart tall filter!
bigbowtielover
bigbowtielover
Loc: Surrey British Columbia
Reg: 09-01-13
11-18-17 09:38 PM - Post#2714907
Oil filter bypass valve prevents oil from passing through the filter when engine is cold.
Execution time: 0.27 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:07 PM
