Username Post: drivers window?        (Topic#348184)
mlrailguy
Loc: Moses Lake,WA USA
Reg: 12-30-02
11-13-17 10:38 AM - Post#2714242
I have electric windows in my 01. The drivers side won't go down, unless I help it. When I don't help, I can hear the motor is running and I hear something inside.
When I push button to go back up, I hear a bunch of crunching and then I can see the window get snug in the window channel again.
Just DUNE it
jktucker92
jktucker92
Reg: 02-05-17
11-13-17 12:43 PM - Post#2714263
    In response to mlrailguy
Sounds like you need a new power window regulator, but the motor could also be an issue. The regulator has cables and pulleys that raise and lower the window. If one or more of the pulleys or cables is broken or worn out, it can cause the window to not go up and down properly. Sometimes, the regulator can fail and also cause damage to the motor gear, in which case both would need replacement.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
11-13-17 07:43 PM - Post#2714300
    In response to jktucker92
I would say either the regulator, common
Or the window itself. It may have broken off the regulator. You will have to pop off the panel to have a look. Should be obvious
Old School GM fan FOREVER
monty56
monty56
Reg: 04-26-04
11-14-17 10:26 AM - Post#2714347
    In response to rockfangd
I found a guy that did my rear window in my 01 burb for $99 locally here in AZ.
Monty
2001 Chevy Suburban 2500
2009 Saturn Vue w/20's
Monty's 56 Truck
Avatar is my Truck
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
11-14-17 05:21 PM - Post#2714381
A new regulator and motor is under $50 and takes about 30 minutes to change if you take your time. That will fix your problem.
Jeff
'88 Chevy K3500, aluminum head roller cam 511inĀ³ stroker 10.5:1 compression, 96 NV 4500, 94-98 grille, 305/70-16 (33x12) BF Goodrich KM2s, 91 cluster swap
11-24-17 07:39 PM - Post#2715613
    In response to bowtie44s
The crunching noise is probably a frayed cable trying to go through a pulley or sheathing. New regulator is the fix.
Execution time: 0.478 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:13 AM
