Username Post: gap of 5/16 between converter and flexplate        (Topic#348180)
Thierry
Thierry
Reg: 04-30-04
11-13-17 07:03 AM - Post#2714224
I am replacing the stock powerglide by a mid seventies th350 in a 67 impala convertible (327). The flexplate was in good condition, no cracks or anything like that, so I left it in place. The torque converter came with the trans and I was told it was a stock converter. With the trans bolted but not torqued to the motor and the converter all the way back in the trans, there is a 5/16 gap between the pads on the converter and the flexplate.
The more I read about it, the more I find that I should shim it with grade 8 washers to reduce the gap. I'm thinking of washers of 1/8in in thickness. When I pull the converter against the flexplate, it's flush with it and it rotates freely with no leak. What do you guys think I should do? leave it alone and bolt it the converter to the flexplate like that or shim it?
Also, I got a Lokar linkage kit with an adjustable bracket, thinking I needed it. It's more of a direct link to the trans as opposed to the stock linkage that has the rod from the column going to a bracket with a pin connected to another spring loaded bracket on the trans. More complicated but perhaps better. Any opinion?
Thanks a lot in advance,
T.
Thierry B. 67 Impala Conv, 327, TH-350
bigbowtielover
bigbowtielover
Loc: Surrey British Columbia
Reg: 09-01-13
11-13-17 11:49 AM - Post#2714253
    In response to Thierry
That is normal clearance . Just bolt it up and go. Use the linkage from a '69-'70 t350 car for column shift. Powerglide linkage is different. You can still use the vertical rod from column. I put a t350 into a '66 impala and used the column linkage from a '70 to make it work.
Thierry
Thierry
Reg: 04-30-04
11-27-17 12:54 PM - Post#2715934
    In response to bigbowtielover
Follow-up: I shimmed the converted to the flexplate with two 1/16 grade 8 washers and 0.75in in length grade 8 bolts from home depot. The 5/16 gap was probably ok but I worried about the fact that all the specs I read said no more than 3/16. I appreciate the answer though.
Linkage is done. PRND lines up. L2 is almost on the L. L1 is further to the right.
I had to redo the double flares on the cooling lines as nuts and fittings were in bad shape. First time doing that. those 5/16 lines are HARD!
I got a holley bracket for the kickdown cable but it's in the way of the stock throttle spring. I think I'll get a bracket for that. The kickdown cable seems to be too long and the ball on the stock qjet carb does not allow to bolt mid way thru the end of the cable. Does anybody know how to solve this?
Thierry
Thierry
Reg: 04-30-04
12-04-17 06:43 AM - Post#2716819
Quick update, I got the car running great with the th-350.
I still have an issue with the throttle and the kickdown cable. The kickdown cable (from a junkyard from an early elcamino) kindda sticks and does not retract back on its own and make the whole thing stiff). I'll post a youtube tonight to show the situation. Thanks for reading.
Thierry
Thierry
Reg: 04-30-04
12-04-17 06:24 PM - Post#2716893
Here is a quick YouTube of the situation
https://youtu.be/hUyTOBxezoo
I forgot to mention that I drilled a small hole in the kickdown plate for the spring to hook up to.
Thierry
Thierry
Reg: 04-30-04
12-15-17 10:33 AM - Post#2718021
Much ado about nothing, I guess. I have 2 springs on either sides, with only 1 slightly in tension when noone is on the gas pedal. It works great now. You probably I'm kind of new to working on cars and replacing the powerglide to a th350 was a BIG job for me, and I learned a lot!
Next is replacing the fuel sending unit, and cleaning up/de-rusting/painting the fuel tank. After that, I'll learn how to MIG weld and replace the rusty metal in the trunk above the rear wells.
I'm sure I'll have plenty of real questions then.
Thanks.
Attachment: IMG_20171214_194303.jpg (4.37 MB) 28 View(s)
Execution time: 0.349 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:33 PM
