Username Post: Oil question        (Topic#348159)
AmericaMade
Reg: 11-06-17
11-11-17 06:38 PM - Post#2714069
My recent truck 1983 Scottsdale C10 has 383 SBC, I am going to do an oil change, what oil viscosity would you suggest using it?
The previous just said "high mileage" type.
2plus2
Loc: Mission,BC
Reg: 02-03-05
11-11-17 06:48 PM - Post#2714070
    In response to AmericaMade
It would help to know what temps you are dealing with outside in winter and summer and if you are towing with it
69 Canadian Pontiac 2+2
elcamino
elcamino
Reg: 03-30-00
11-11-17 07:29 PM - Post#2714077
10W-30 is the recommended viscosity for that model year. Grab what every brand catches you eye at Walmart.
2017 GMC Sierra Denali Ultimate 6.2L(420hp)/8-sp
2016 Polaris RZR 900 EPS
AmericaMade
Reg: 11-06-17
11-11-17 07:32 PM - Post#2714078
    In response to 2plus2
No towing,
In SouthWest desert
Not a daily driver
2plus2
Loc: Mission,BC
Reg: 02-03-05
11-11-17 08:45 PM - Post#2714090
    In response to elcamino
This
A good 10w30
What kind of cam?roller?flat tappet?
Senior Chevytalk Moderator
11-12-17 05:33 AM - Post#2714110
Castrol 10-30wt. I use it on my ZZ4 in Texas hot weather. In the original 305, Castrol 10-30wt saved the engine twice. Each time it over heated. Once for a busted hose. A second time for a leaking heater core.
TAT_2
"17th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
11-12-17 06:11 PM - Post#2714188
ACTUALLY EXPERIANCED A OIL SEPERATION/CONTAMINATION WITH CASTROL GTX 5W-20. THE VIBE ONLY HOLDS 4.5 QTS SO I HAD A .5 QT LEFT OVER FROM ABOUT 2010.I HAD IT IN THE SHEAD & JUST USED IT FOR MAKE UP OIL IN MY PUSH MOWER.I NEEDED A LITTLE OIL IN THE G6 SO I HAD SOME OTHER BRANDS LAYEN AROUND. STARTED PORING THE GTX IN THE FUNNEL,IT WASN'T GOING DOWN 2FAST,I NOTICED A CLEAR GOO CLOGGING THE SS/MESH IN THE FUNNEL,WEIRD !!!I HAVE OTHER NEW OIL STORED IN GLASS JARS,ALL THAT WAS OK,IM WONDERING IF THE PLASTIC DETERIORATED & WAS FLOATING IN THE OIL ?IM PRETTY SURE IT WASN'T WATER.
09 PONTIAC- VIBE
08 PONTIAC- G6
96 FURD F-150 SUPER CAB XLT 4X4
NEXT ?
11-13-17 05:26 AM - Post#2714221
    In response to TAT_2
Good point. I didn't mention I use 1 quart of Lucas oil additive. It replaces one full quart of oil. The additive sticks to parts better after shutdown. Valve ticking on cold starts is almost gone since I've started using oil additive. I use it especially on my '08 Nitro that calls for 5-20wt oil. The light oil caused a lot of rocker arm clatter on morning starts. Now, it rarely clatters and it's really quite when running.
elcamino
elcamino
Reg: 03-30-00
11-19-17 02:25 PM - Post#2714956
Today's high-quality engine lubricating oils are very sophisticated. Most oils already contain precise amounts of additives blended into the lubricating oil to meet stringent performance requirements. These oils meet performance characteristics that conform to the lubricant industry standards and are sufficient protection when used according to the recommendations. Aftermarket lubricating oil additives are not necessary to enhance engine oil performance and may in some cases reduce the oil's capability to protect the engine.
11-19-17 04:31 PM - Post#2714974
Dodge engine designs are notorious for ticking. Especially the overhead cams in 3.7 and 4.7 engines. Both use 5-20 wt oil. I drive a 3.7 and fixed a 4.7 for my dad. The lash adjusters lose movement over time. Light oil will not stick to parts. My Nitro engine is a lot quieter using the Lucas additive. Without it, clatter is very loud. I've noticed that oil change mileage increased using Lucas. Straight oil run less miles. On my experience, I'll stick to using a Lucas quart for overhead cam engines.
AmericaMade
Reg: 11-06-17
11-30-17 02:12 PM - Post#2716426
How do I get this off to put oil in? Do I just pull it out? I tried turning but the metal piece just spins
upload temporary image
Edited by AmericaMade on 11-30-17 02:14 PM. Reason for edit: Image upload issue
11-30-17 05:06 PM - Post#2716445
Pull up on it. It’s two a two prong metal base. The prongs have to squeeze together to clear the opening.
AmericaMade
Reg: 11-06-17
11-30-17 06:49 PM - Post#2716459
Thanks for all your help. I appreciate it.
AmericaMade
Reg: 11-06-17
11-30-17 06:53 PM - Post#2716460
i just pour the oil in there?
11-30-17 07:05 PM - Post#2716463
Yes, slowly as there may be a baffle in the valve cover.
AmericaMade
Reg: 11-06-17
11-30-17 07:09 PM - Post#2716464
Im doing this tomorrow. Ive never added oil like this just wanted to be sure Im doing it right.
Execution time: 0.247 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:08 PM
