Username Post: Battery Drain Part III        (Topic#348146)
rod
Loc: kingman,az
Reg: 04-29-00
11-10-17 05:31 PM - Post#2713956
2000 S-10 Blazer. I checked all the fuses under the hood. battery voltage after setting 3 days was 11.97. all fuses read 0 draw with these exceptions.
ECM B read 10.98, MIR/LKS read .02 & RR/WW read .03
I have no idea if the ECM is supposed to have volts or not. I assume the MIR/LKS is the power mirror adjustment and LKS is the power door locks. why would they draw? and lastly why would the rear window washer draw. in post II, I found the cruise control had a .02 draw.
all totaled, I guess it would knock the battery down after setting a few days. the question is, how do I cure this?
any help will be appreciated.
Thanks Rod in AZ
rod
Loc: kingman,az
Reg: 04-29-00
11-10-17 08:11 PM - Post#2713967
    In response to rod
I was setting inside the Blazer tonight, when it was dark, to check for any light which might be on. I found something which I thought was strange. the driver power seat adjustment works when the key is off! is that normal?
Rod in AZ
SleeperSS
Loc: Spanaway, Wa
Reg: 10-17-04
11-11-17 06:27 AM - Post#2713993
    In response to rod
That's normal...
U.S.C.G. "So others may live"
'96 S-10 SS
'02 BlaZeR2
Senior Chevytalk Moderator
11-11-17 06:29 PM - Post#2714067
    In response to SleeperSS
Yup, my 95 has power without the key.
One of your locks could be bad. Or a switch.
SleeperSS
Loc: Spanaway, Wa
Reg: 10-17-04
11-12-17 09:54 AM - Post#2714132
    In response to rod
ECM should power down with key off.
'96 S-10 SS
'02 BlaZeR2
rod
Loc: kingman,az
Reg: 04-29-00
11-22-17 04:40 PM - Post#2715368
in the big truck forum, someone said disconnect the oil pressure wire. every heard of that? also disconnect the fuel pump. I had the pump replaced last year. suppose there is a possibility that a wire/s got mushed? have never looked under it.
I pulled the rear washer fuse [under hood] and the steering wheel light [at the dash] both had a .004 draw. over night the battery fell from 11.87 to 11.76. radio battery draws 10.75. is that normal?
what happens if the ECM does not power down? replacement time or?
Thanks Rod in AZ
rod
Loc: kingman,az
Reg: 04-29-00
11-23-17 07:01 PM - Post#2715520
    In response to rod
more ?s in addition to the ones posted just above. what happens if I pull the radio battery fuse? also what happens if I pull the ECM fuse?
or would it just be easier to disconnect the battery ground. how long before things get screwed up?
Thanks Rod in AZ
SleeperSS
Loc: Spanaway, Wa
Reg: 10-17-04
11-24-17 06:33 PM - Post#2715606
    In response to rod
You'll lose you radio programing..but that's about it. Pull the ecm fuse(s) and see if that helps.
'96 S-10 SS
'02 BlaZeR2
11-26-17 05:42 AM - Post#2715753
My '95 had a radio problem. It was not working. I traced it back to a pulled fuse. I put one in. The radio clock started rolling and would not stop. It's the power fuse when the key is turned off. Eventually, I replaced the radio. Stock radios over time do fail in weird ways. Is yours still stock? Any amps or accessories added?
rod
Loc: kingman,az
Reg: 04-29-00
11-30-17 02:49 PM - Post#2716433
volt readings thru the week. 12.5 Sun. 12.01 M, 11.80 T, 11.67 W & 11.60 today [Thur]. I had pulled the front and rear wiper fuse, the steering wheel light [still dont know what that is] the drain was still present. So I gave up and took it to an auto electric repair shop this morning.I will post the results when Roger is done.
Thanks all for all the help and answers.
Rod in AZ
Execution time: 0.943 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:54 PM
