Username Post: 54 Jaguar IFS conversion        (Topic#348142)
Ben 1954
Ben 1954
Loc: West Houston, TX
Reg: 01-10-05
11-10-17 12:37 PM - Post#2713920
I installed the Jaguar XJ6 front end in my 1954 chevy belair.
I took it to get aligned but found that I have too much negative camber. Even with all the shims removed, there is still 2 degrees of negative camber. Any of you guys that have done the Jag IFS swamp run into this problem?
If so, were you able to find a solution?
Regards,
Ben
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
11-10-17 01:18 PM - Post#2713925
    In response to Ben 1954
You need too add shims to the front of the upper a arm , that will move the top of the spindle forward to give you positive camber.
Edited by cbmkr56 on 11-10-17 01:19 PM. Reason for edit: No reason given.
Ben 1954
Ben 1954
Reg: 01-10-05
11-10-17 02:23 PM - Post#2713930
    In response to cbmkr56
My understanding is that the camber is the "verticality" of the Tire. Maybe I am mistaken.
I don't understand how adding shims to the front of the upper arm will improve the situation.
Can you explain further?
Regards,
Ben
VANDENPLAS
VANDENPLAS
Loc: ontario canada
Reg: 07-29-09
11-10-17 03:43 PM - Post#2713947
Where the upper control arm bolt to the subframe ( 2 studs coming out of the frame holding upper control arm pivot )
You need to add shims to gain positive camber and remove shims for negative camber
The shims go between the arm and the sub frame pushing the upper arm out ( in front of the frame will do nothing )
Castor is adjust with shims on the front or rear side of the upper control arm essentially pushing the arm forward or back from true vertical
The shims are readily available at a jag dealer if they still have these cars in there fleet
Or fender shims or Chevy camber shims will work also
Just FYI rear camber on a jag diff is done by shimming the axle shaft on the diff flange
Edited by VANDENPLAS on 11-10-17 03:46 PM. Reason for edit: No reason given.
Ben 1954
Ben 1954
Reg: 01-10-05
11-10-17 07:24 PM - Post#2713965
    In response to VANDENPLAS
All of the shims have been removed from the top of the control arm. Even with all shims removed there is still negative camber. The suggestion from the alignment shop was that the front end needed to be lowered about 2 inches to make the alignment correct. I don't want to lower the front, so was looking for another solution.
Regards,
Ben
Ben 1954
Ben 1954
Reg: 01-10-05
11-10-17 08:42 PM - Post#2713969
It seems as though the front of the car is not heavy enough or the coil springs are too strong.
Regards,
Ben
11-11-17 12:42 AM - Post#2713978
  • VANDENPLAS Said:
........You need to add shims to gain positive camber.......
Was this done?
VANDENPLAS
VANDENPLAS
Loc: ontario canada
Reg: 07-29-09
11-11-17 04:43 AM - Post#2713979
You need to add shims between the control arm and the frame to push the arm out to gain positives camber removing shims gives negative
Look up the jag series 3 suspension to clairfiy this for you
Also how is the alignment shop doing the alignmemnt? Going by 50 Chevy or jaguar specs won't work, they need to look at the live data and use some math and brain matter and make it work " twisting till it's all green " won't work as the specs are not accurate
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
11-11-17 05:51 AM - Post#2713985
Hi Guys, Rule one of wheel alignment.
Tire fitters can't do custom wheel alignment applications!.
Also, you need to make sure that you are duplicating the load situation that is required for the specifications given. Some Jag fronts are set at half load, not empty, and you are supposed to get the ride height correct first.
The English use different terms and names from US practice and Jaguar seemed to be particularly good at setting traps for the unwary. If you think you could jump from working on Chevy/Ford/etc sixes and could service a Jaguar then they were more than happy to show you how foolish that assumption was.
On all the sixes I worked on No1 cylinder is at the front, on an early Jaguar six, it is at the back.
Cheers Kiwi
Edited by Bel Air kiwi on 11-11-17 05:58 AM. Reason for edit: No reason given.
VANDENPLAS
VANDENPLAS
Loc: ontario canada
Reg: 07-29-09
11-11-17 06:05 AM - Post#2713987
    In response to Bel Air kiwi
YES KIWI your right I just 'a'membered jaguars curb weight for the series 3 was totalled with a full tank of fuel and 4 passengers in the car !
We had these weighted bags to put in all 4 seats and had to fill the fuel tank to do alignmemnts !! Sh!t completely forgot about that!
Jag had this set up for alignment but untill 94-97 around there
Thanks from making me 'amemeber
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
11-11-17 06:29 AM - Post#2713994
Hi VDP, that should read "fill both fuel tanks"
Cheers Kiwi
ps. you can also measure it on the headlight centers and then check ground clearance. Then ....
Edited by Bel Air kiwi on 11-11-17 06:31 AM. Reason for edit: No reason given.
11-11-17 08:46 AM - Post#2714008
  • Bel Air kiwi Said:
Hi VDP, that should read "fill both fuel tanks" ................
Ahhh, that brought back memories. One of the coolest things about the XJ-12 I restored for SWMBO was pulling into the gas station and popping those beautiful chrome gas caps and fillin' 'er up... the Jag that is, not SWMBO. I better shut up.
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
11-12-17 06:32 PM - Post#2714190
Yes it is vertical, when you shim the front of the a arm towards the center of the car the spindle will lean forward. You can also roll the k member of the suspension forward to get the same effect.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
11-12-17 06:44 PM - Post#2714191
Hi Robert, She should have been worshiping you. Those early V12's were magnificent cars when new.
A century ago when I did my apprenticeship one of our clients had a new S3 V12 and he used it for going on 600 mile intercity runs as he had a morbid fear of flying.
The owner used to regularly max it out on these trips so you can image what his fuel bills were like.
It wasn't quite as quiet as a Bentley I used to service but had it's measure in every other way.
The manager of the place I worked had a restored 4.2 "E"type coupe, I never got to drive that but it was a superb drivers car.
Cheers Kiwi
11-12-17 08:15 PM - Post#2714202
That XJ-12 was a great car except for the many times it wouldn't start or the times it died on the highway.
flatout
flatout
Loc: NW
Reg: 12-15-01
11-17-17 01:51 PM - Post#2714781
If you’re trying to move the top of the tire out, you have to remove shims. If you’ve removed them all and it’s still too far in, you could remove the 1/8” angle under the control arm shaft. I suppose it will weaken it some. You could reinforce it another way.
Edited by flatout on 11-21-17 02:03 PM. Reason for edit: No reason given.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
11-17-17 10:51 PM - Post#2714823
    In response to flatout
Hi Flatout, nice top shock mounts. On a Jag you don't actually remove the spacers from the top, you should just swap them from one side to the other, and always have the stock 8 spacers.
Cheers Kiwi
flatout
flatout
Loc: NW
Reg: 12-15-01
11-18-17 08:02 PM - Post#2714897
I believe the OP was talking about camber. The shims sandwiched with the ball joints is for caster adjustment, and you’re right, they are just shuffled around for caster adjustment
Edited by flatout on 11-18-17 08:08 PM. Reason for edit: No reason given.
Ben 1954
Ben 1954
Reg: 01-10-05
11-20-17 07:57 AM - Post#2715058
It turns out that the front end had shims already installed from the previous application. I removed the shims which moved the top control arms further towards the outside of the car. Doing this fixed the camber issue that I was having when the front end was initially installed.
Thanks for all the help.
Regards,
Ben
flatout
flatout
Loc: NW
Reg: 12-15-01
11-20-17 08:48 AM - Post#2715070
I thought you had already removed the shims. However, I'm glad you got it all worked out. Good luck with your project.
11-20-17 03:58 PM - Post#2715114
Glad you got it handled Ben. Let us know how you like it.
Ben 1954
Ben 1954
Reg: 01-10-05
11-22-17 08:00 AM - Post#2715306
The shim thing was a little confusing at first. I didn't realize when I first looked at the front end that the shims that had been used were actually washers. I could not tell that the washers were installed until I removed the upper bolts that hold on the arms. Once I removed the bolts, it was easy to see the washer shims and remove them.
As far as enjoying the change, I love it. The comfort of the ride is great, power steering really helps when parking, and the braking is much improved. I would recommend this change to anyone. The car handles well, stops well and rides well.
Thanks for all the help and for those that have done this swap before and offered their information. I appreciate it.
Regards,
Ben
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
11-22-17 08:54 AM - Post#2715322
Glad you got it worked out. Now you can enjoy a great ride.
Execution time: 0.214 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:11 AM
