Username Post: Steering box rebuild        (Topic#348138)
64belaire
64belaire
Reg: 10-04-09
11-10-17 10:25 AM - Post#2713902
Working on my 64 Belair with power assist steering & didnt see any info in a search.
I was replacing the control unit last weekend & noticed play in the pitman arm side of my gear box. After looking at a few rebuild kits Im not seeing the geared shafts available.
Not sure if the kits will fix the issue or am I doomed to replace the box itself?
64ausbelair
64ausbelair
Loc: Australia (QLD)
Reg: 10-26-06
11-10-17 02:00 PM - Post#2713928
    In response to 64belaire
Hey mate.
What movement are you seeing? Side to side movement or up down on the shaft. I know you can buy a rebuild kit that has the bushings in it which may be your problem if its side to side movement.
If it's up down type movement then it may need a slight adjustment. Or if your adjusting bolt is worn where it slots into the sector shaft, this will give you up down movement also.
In saying that I thought I had seen new sector shafts and worm gears etc while surfing the web for box parts.
Jason.
64belaire
64belaire
Reg: 10-04-09
11-10-17 03:40 PM - Post#2713945
    In response to 64ausbelair
Its side to side play & not sure how long its been that way. I put the motor in 2014 & reworked the suspension back in 2010. With it having air ride i shake the front in down at least every 2 months.
Im hoping its just the bushing & pitman shaft seal
64ausbelair
64ausbelair
Reg: 10-26-06
11-11-17 12:04 AM - Post#2713977
Have a crack at new bushings and seals. They're not that exy. If the sector gear shaft is worn too much and you're still getting excessive movement make your next decision.
Jason
Execution time: 0.804 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:07 AM
