Username Post: Gear Selector Adjustment        (Topic#348124)
steveimpala
Loc: Dutchess County, New York
Reg: 04-02-12
11-09-17 09:04 AM - Post#2713767
I have a 1969 Chevrolet C20 with a Turbo 400 transmission. The column selector can be difficult at times going from park to drive... is there a way to make an adjustment so that the selection is a lot smoother going from gear to gear ?
Member:
-National Impala Association
-Antique Automobile Club of America
1986 Chevrolet Monte Carlo SS
1969 Chevrolet Impala Custom - Frost Green
1969 Chevrolet Impala SS427 project - Frost Green
bobschevytrucks.com Ecklers
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
11-09-17 09:15 AM - Post#2713773
    In response to steveimpala
steve,
It sounds like the bushings on your linkage are worn out. Given the year model of your truck I'd say that it's probable.
Driving, and thus working on our older vehicles, sometimes it's hard to keep in mind that they were new at one time. Chevrolet didn't let it leave the assembly line if things weren't working right. That said, wear is usually the first thing to look at on peripheral items.
I am always looking to make sure the engine, trans, brakes, etc are in good shape. I take for granted that everything else works like it was intended. Wear happens to all components, not just the drivetrain.
Good luck,
Griff
if you're gonna be a bear................
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
steveimpala
Reg: 04-02-12
11-09-17 09:49 AM - Post#2713777
    In response to beagrizzly
Thanks for the info...
Member:
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
11-09-17 07:23 PM - Post#2713839
Squirt some wd-40 or whatever in the column ,I remove shift arm from colum then give a couple squirts. Usually it will free it up might be able to put the straw of wd in between arm and column and squirt
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
63 IMPALA 2/DR HRDTOP 327
steveimpala
Reg: 04-02-12
11-09-17 10:24 PM - Post#2713857
    In response to 69_BOWTIE
Thanks.... I gave it a shot and it does move a lot smoother now.... still going to check out the bushings, truck has 87,000 miles on it.
Steve
Member:
JimKshortstep4x4
Chevytalk Moderator & "14th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
11-13-17 05:34 PM - Post#2714287
69 Bowtie's method works good to free up the column slide which moves in the upper part of the column.
After freeing the column with penetrant, I use the spray grease that thickens and lubes longer then most penetrants. Lubing the lower mechanism is recommended, also.
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
Execution time: 0.708 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:12 PM
