Username Post: Modern fuel damages fuel tank float        (Topic#348109)
Aussie_Chevy_Nut
Aussie_Chevy_Nut
Loc: Australia
11-07-17 07:54 PM - Post#2713623
A couple of years ago I tracked down a fuel gauge fault: The float was not floating. I pulled the sender and found the float was full of fuel. So I changed the whole sender unit and all was ok, for a while!
Now the gauge is acting up again, a full tank shows almost empty so I am going to pull the sender and float to see if the same problem is happening again.
I spoke to my local Classic Chevy Parts dealer here in Australia and he said that modern fuels are causing the floats to dissolve in the tank. Apparently this is a rather common problem, at least here in Australia. Our fuels do not contain lead and Ethanol is available but the Government is having a hard time getting folks to use it because it has a bad reputation as bad for all cars, not just classics.
I wonder if anyone has heard of this problem and whether they know whether there are better floats available somewhere. My car is '59 Impala 2 door hardtop with 348 tri power.
Cheers, John
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
11-08-17 05:55 PM - Post#2713703
    In response to Aussie_Chevy_Nut
Hi John, There are plastics that will last a thousand years in fuels, but parts fakers don't use them.
You could try going to an old carb guy and see if he has a brass float he can adapt on.
It should read reasonably true if its about the same volume. The old floats are thin wall so should weigh about the same as plastic.
Cheers Kiwi
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
11-08-17 06:23 PM - Post#2713707
    In response to Bel Air kiwi
There is a Ford plastic float that fits, I picked one up 10 years ago at the local Ford dealer, it was common and was on his shelf. Do some searching on here the part number may show up and you might get it locally. I avoid ethanol in anything with a carb.
Member #2194
DonSSDD
DonSSDD
Reg: 08-21-01
11-08-17 06:33 PM - Post#2713708
    In response to DonSSDD
Found one, part number is COAZ9202-B but this one is brass. The one I found was black plastic. The brass one is $6 at Summit, but you may find it locally.
Member #2194
larrybrowningmauldin
Loc: New Braunfels,TX
Reg: 08-16-05
11-09-17 06:58 AM - Post#2713749
The brass Ford C..... floats does work well as numerous Chevy Talk members, including myself, have reported. Bon chance
Aussie_Chevy_Nut
Aussie_Chevy_Nut
Loc: Australia
11-10-17 03:02 AM - Post#2713866
    In response to larrybrowningmauldin
Hi Guys,
Thanks for all the suggestions, I will pull the sender out this week and report back what I find, Cheers, John
Carl1962
Carl1962
Loc: Bungendore Australia
Reg: 04-01-10
11-10-17 03:35 AM - Post#2713869
G'day John, is your 59 float the same style as in 62? I replaced my original sender unit a couple of years ago when the fuel sender potentiometer went kaput. I replaced the whole sender unit and fixed the fault and I kept the old sender with a perfectly buoyant brass float. It's yours if you want it. I think I can just pull it off the wire arm as there is a groove in the float.
Attachment: DSCN2178.JPG (2.06 MB) 10 View(s)
Cheers, Carl.
1962 SS Impala Sports Coupe
http://s465.photobucket.com/albums/rr18/1956Carlo s...
Aussie_Chevy_Nut
Aussie_Chevy_Nut
Loc: Australia
11-12-17 01:26 PM - Post#2714165
    In response to Carl1962
Hi Carl,
Thanks for the offer. I'll take you up on that if I may.
I am of course assuminng that the float is the culprit.
I will know for sure once I get the sender unit out. Nota job I am looking forward to!
Cheers,
Carl1962
Carl1962
Reg: 04-01-10
11-13-17 02:41 AM - Post#2714212
No worries John, must be harder than a 62, I can get it out of my 62 in about 10 mins. I had lots of practice chasing the problem with my fuel system. Send me an email when you get yours out I'll send this one up to you.
Cheers, Carl.
Hugomiller
Hugomiller
Loc: Florida and UK
Reg: 05-02-17
11-14-17 04:21 AM - Post#2714323
Anybody tried cork?
Aussie_Chevy_Nut
Aussie_Chevy_Nut
Loc: Australia
11-14-17 04:41 AM - Post#2714325
    In response to Hugomiller
Cork floats but can break up into small pieces that could travel to a car by not protected by a filter. Never heard of a cork being used.
4dr 57
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
11-14-17 08:14 PM - Post#2714418
I was having a problem too until I got asend unit for Impala Bob's Classic Chevy Parts. It was set up right out of the box. I checked it with an ohm meter and it read real close to 0 at the bottom and 30+ at the top.
the eBay floats I've seen all show the float arm quite a way away from the pickup and that's waay wrong. They come that way too. Ask me....
Execution time: 0.187 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:35 AM
