Username Post: wanted metal door lock pins        (Topic#348093)
hand123
Reg: 07-15-12
11-06-17 06:58 PM - Post#2713520
Hello. I'm looking for metal door lock pins. I want to mount little skull valve stem caps on the tops for a cool effect to my hot rod. I keep breaking plastic ones, so I'm looking for metal ones. Are all door lock pins the same; and by that I mean will the metal Mercedes ones work for my purpose?
Anyone have any cool suggestions?
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
11-06-17 10:04 PM - Post#2713533
    In response to hand123
Hi Hand123, Probably not as ours are imperial thread and the Mercedes will be metric thread.
Try the aftermarket on e-bay, once you find out what thread ours are.
Cheers kiwi
DanD1950
DanD1950
Loc: London Ont. Canada
Reg: 10-16-11
11-07-17 02:31 AM - Post#2713540
Skull Pulls
Dan.
50 Styleline Deluxe, 2 Door Sedan, Was a 216cu", Three Speed Manual. She now has a 4.8Lt V8 LR4 injected engine, 4L60E 4 speed automatic, 10 bolt diff 342 gear with an Eaton C80 Locker
Sheldon Y.
Loc: Waltham, Massachusetts
Reg: 10-29-16
11-07-17 04:19 AM - Post#2713543
    In response to Bel Air kiwi
I have a whole drawer full of Metal ones.
I'll check the fitment on my '49 if you want.
They do make Skull Pulls done, though.
'49 Styleline Deluxe Build@
https://www.jalopyjournal.com/forum/threads/49-styl eline-deluxe-project-fran kenstyle.1079870/
http://www.frankenrodz.com/frankenstyle.html
hand123
Reg: 07-15-12
11-07-17 05:49 AM - Post#2713550
    In response to DanD1950
  • DanD1950 Said:
Unfortunately, I believe these are chromed plastic. I'll keep searching. Thank you.
hand123
Reg: 07-15-12
11-07-17 05:51 AM - Post#2713551
    In response to Sheldon Y.
Yes, please let me know about what you have.
I bought something like these, but the posts were thin plastic and kept breaking. Which is why I'm looking to create a metal solution.
https://www.ebay.com/itm/2-Made-in-USA-Sku ll-Door-...
Thank you.
hand123
Reg: 07-15-12
11-07-17 06:26 AM - Post#2713558
Sheldon,
I found the following to compare.
https://www.streetrodhq.com/detail/42302/Chrome_M e...
2D51STYDLX
2D51STYDLX
Loc: So. Prairie Washington
Reg: 03-03-11
11-07-17 08:39 AM - Post#2713569
If you can't find metal ones, get some metal tubing and glue it over the posts, they also have threaded metal tubing, cut the posts off drill into skull glue in posts ?
Roger
1951 2 door Deluxe Bone stock, well not quite, bucket seats.
Broken hearts and dirty windows
Make life difficult to see
Thats why last night and this morning
Always look the same to me
John Prine
hand123
Reg: 07-15-12
11-08-17 07:41 PM - Post#2713726
    In response to 2D51STYDLX
These work great and you can attach a topper of your choice.
https://www.streetrodhq.com/detail/42302/Chrome_M etal_Tube_Door_Lock_Knob.html
Edited by hand123 on 11-15-17 07:48 PM. Reason for edit: No reason given.
Execution time: 0.214 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:58 AM
