Username Post: L29 7.4L 454 noise        (Topic#348079)
Big Chevy
Big Chevy
Reg: 11-06-17
11-06-17 11:37 AM - Post#2713438
I recently bought my brother's '99 Suburban, that's been sitting for a very long time. It has a ticking noise that I just can't figure out. I added an oil treatment a few weeks ago, and 'stethoscoped' everything I could, and nothing. The noise is everywhere it seems. Anyone have any answers?
Edited by Big Chevy on 11-06-17 11:39 AM. Reason for edit: No reason given.
11-06-17 12:46 PM - Post#2713446
    In response to Big Chevy
Welcome to Chevytalk,
How many miles on it, and do you know how it was maintained previously?
These engines have non-adjustable rockers. Instead of a stud with a locknut, they are simply bolted in and torqued to spec.
So if they are worn, they will tick. Could also be a bent pushrod (or several) if the engine has been over-revved. Finally, if the tick is significant, it could be a failed lifter.
Comp Cams sells an inexpensive kit to convert the rockers to adjustable. It has studs with the correct sized threads to screw into the heads, spacers to go into the stock rockers, and new locknuts. It's about $100. I will caution you that I had trouble with this kit the first time I bought it and the locknuts damaged the threads on a couple of the studs. I put everything back together stock for a while but the ticking got to me and I bought the kit again and took my chances; worked out OK second time around.
Big Chevy
Big Chevy
Reg: 11-06-17
11-07-17 11:19 AM - Post#2713576
    In response to someotherguy
I made the mistake of going through private email, Richard. Don't know if you got it, but here's the recap: The truck only has 60k miles on it, has been terribly neglected/not even driven in the last 6 years. It has sat in my brother's yard mostly unattended, and may have rat damage. I'm sure everything on it is original from the factory, except a few things I've done for it to date. The previous owner before my brother apparently worshiped the vehicle, and if the paint is any evidence, he must have garaged it if he wasn't driving it. The original/first owner, I haven't any idea how they took care of it, but it was a special order, with every option for towing/camping. I'm beginning to think my ignition system may have rat damage, and the noise I'm hearing is external spark action. When I feel like spending more money on it, after new tires, shocks, stereo and odds and ends, I'm going to invest in new wires and plugs. I just don't want to believe I may have piston slap, or even rocker issues. I can't hear anything in there, and this sound is everywhere, and nowhere in particular. I suppose I could wet the ground, stand in my bare feet and grab hold of the block and see if I don't get launched out of the puddle... otherwise, it's easier to just replace these components than to test each wire individually.
Sam
11-07-17 11:30 AM - Post#2713577
Yeah, at 60K I would seriously doubt any wear/damage in the valvetrain unless the truck showed signs of real abuse.
One method that can help find leaking spark is to run the engine in a dark garage, and mist it with a spray bottle. Just take care not to get too close to any moving parts in an unfamiliar engine bay in the dark!
Don't overlook leaking exhaust joints or leaks elsewhere. Truck may be low mileage but if it sat a lot, and was just cranked up every now and then, a lot of condensation may have sat in the exhaust and rotted through somewhere.
Big Chevy
Big Chevy
Reg: 11-06-17
11-07-17 12:02 PM - Post#2713580
Very god suggestion! Never thought about the dark and a spray bottle. And, yeah, fans and such can really make for a bad experience! Eventually, I'm going to go with some headers and dual exhaust, anyhow. Thanks again!
Sam
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
11-07-17 05:22 PM - Post#2713606
What did you use for a stethoscope? My uncle likes to use a piece of heater hose. I have not had any reason to do it myself, yet.
What kind of oil treatment did you use? A lot of that stuff is just a money grab, in my opinion. If I use anything besides engine oil, it's Marvel Mystery Oil.
My engine ticks a bit when cold, but I don't notice much after it warms up. I have over 275K miles on my engine.
99 K3500 RCLB
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
11-08-17 03:44 AM - Post#2713635
    In response to 454cid
You can get a mechanic's stethoscope at Harbor Freight for around $4. They actually work pretty well.
Jeff
'88 Chevy K3500, aluminum head roller cam 511inĀ³ stroker 10.5:1 compression, 96 NV 4500, 94-98 grille, 305/70-16 (33x12) BF Goodrich KM2s, 91 cluster swap
11-08-17 08:56 AM - Post#2713656
    In response to bowtie44s
Dunno about the HF one but I bought one years ago from Lisle. Anyway the metal probe end of it is really useful as it lets you know pretty clearly when you've touched it on whatever is making noise.
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
11-08-17 12:35 PM - Post#2713664
The advantage of the hose is that it's all rubber. You can't short anything with it, and if it gets caught in the belt drive it likely won't do any damage.
99 K3500 RCLB
Execution time: 2.022 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:00 PM
