LMC Truck
Username Post: Rear axle        (Topic#348060)
J C
Loc: Orange Co. Calif
Reg: 04-17-04
11-05-17 02:02 PM - Post#2713345
2007 Suburban. Tried to pull the rear axle. Got the c clip out but axle would only come out about 1/8 in.on the passenger side. Could not get the drivers axle in far enough to remove the c clip. Finally gave up and tried to put the passenger axle completely in but it would not go. Like I said we only were able to move it about 1/8 to 1/4 in out so it was never out all the way. Been trying to align things but nothing works. any help Thanks.
69RSZ28 71 Chevelle 79 Silverado 24K mi.
Edited by J C on 11-06-17 07:17 AM. Reason for edit: No reason given.
LMC Trucks
J C
Reg: 04-17-04
11-05-17 05:12 PM - Post#2713369
    In response to J C
Finally after numerous attempts the axle finally went in. I still don't know why the right side axle would not come all the way out or why we could not push the drivers axle in far enough to pull the c clip. If anyone knows the answer it would be helpful because we are going to have to replace rear wheel bearings. Thanks.
rockfangd
Loc: Utica ny
Reg: 04-13-10
11-06-17 07:56 PM - Post#2713526
    In response to J C
Could it be the axle seals?
MAybe you could post a picture of the axle tube with the seal in it.
Could be pressed into both the axle and the tube
Old School GM fan FOREVER
11-08-17 10:35 AM - Post#2713659
    In response to J C
Did you check if the brakes are keeping the shaft from freely moving in/out? If you have already removed any interfering brake components, please disregard this.
Frosty690003
Loc: California
Reg: 04-01-06
11-13-17 06:20 PM - Post#2714298
    In response to rockfangd
We had everything removed so it was just the axle. Unfortunately I did not take a picture and it's all back together now. From everything I read and what it looked like once the c clip was removed it should have slid right out. Felt like I would have really had to hit on it hard to break it loose but did not want to risk it. Wondering if the axle shaft may be bent and or wore out? Not sure
2000 Silverado Z-71
2007 Suburban
1969 Chevelle
2009 Daytona 675
2006 Centurian Elite
"You can never have too many toys"
LMC Trucks
Execution time: 0.218 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:47 PM
