Username Post: Spark plug issue        (Topic#348059)
Techhead
Techhead
Loc: Etobicoke, Canada
Reg: 10-25-05
11-05-17 01:06 PM - Post#2713342
Just getting my 1970 SBC back together after about 8 years of sitting on a stand.
I had completely forgot that I swapped the heads back then.
The old plugs that I had sitting in a box were AC Delco R45S, so I had purchased new replacements.
I was pulling my hair out trying to install them but the body of the plug will not fit the plug hole.
Just to test my theory out I took a flap disk to one plug and removed some metal so the body was the same size as the crush washer.
I was able to screw the plug all the way to the seat.
Question is, is there a plug with a slimmer body that I can purchase? Anybody know a part number? Would hate to flap disk all the ones I have to make them work.
Links not working..
If you know how to cut and paste then remove the space, you can see what I've done.
[image]http://ontariorodd erscomunity.activeboard.com/download.spark?ID=2092853&aBID =161738[/image]
[image]http://ontariorodd erscomunity.activeboard.com/download.spark?ID=2092899&aBID =161738[/image]
[image]http://ontariorodd erscomunity.activeboard.com/download.spark?ID=2092900&aBID =161738[/image]
58 Delray in disaray
Edited by Techhead on 11-05-17 01:11 PM. Reason for edit: No reason given.
11-05-17 04:15 PM - Post#2713363
    In response to Techhead
Couldn't get to the links, are you saying the std 14mm plug wont screw into the head or the body of the plug interferes with the header?
TAT_2
"17th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
11-05-17 05:10 PM - Post#2713368
YA PROABLY NEED A CONICAL SHAPED PLUG FOR THEM HEADS
https://shop.advanceautoparts.com/p/acdelco-rapidf...
LOOK UP A R45TS PLUG
09 PONTIAC- VIBE
08 PONTIAC- G6
96 FURD F-150 SUPER CAB XLT 4X4
NEXT ?
Techhead
Techhead
Reg: 10-25-05
11-05-17 06:27 PM - Post#2713379
    In response to TAT_2
The body of the plug will not fit the exisiting hole to even thread into the head.
ThanX TAT+2,
It hadn't occurred to me at the time until I started searching on line for a solution.
I'll be hitting the local jobber in the morning.
TAT_2
TAT_2
Reg: 10-29-00
11-06-17 05:54 AM - Post#2713407
YOUR WELCOME
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
Techhead
Techhead
Reg: 10-25-05
11-06-17 11:11 AM - Post#2713442
Plugs are in and why is it that wire sets never have the proper length in one kit?
Got to dig through another set I've got so I can clean up the wires.
farm rat
Reg: 09-13-16
11-06-17 01:12 PM - Post#2713460
I used taylor wires from Summit and there was more than enough length to get the job. Almost too much.
TAT_2
TAT_2
Reg: 10-29-00
11-06-17 03:47 PM - Post#2713486
DEPENDS,THAY HAVE OVER & UNDER SETS,I LIKE "MOTOR CRAFT" WIRES 8.5 DIA,THE UNDER SETS USUALLY WORK BETTER THAN THE OVER WITH HEADERS & MUCH LONGER.
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
Execution time: 0.233 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:21 AM
