Username Post: 2003 Malibu HVAC Fuse Blowing, Short in system?        (Topic#348048)
BigDamnArtist
Reg: 11-04-17
11-04-17 03:01 PM - Post#2713272
So first some background, I'm not really a car guy (I can stumble through but that's about it), so just trying to see if anyone else has run into this and if it's something I can deal with myself. Secondly, I'm in Central Alberta, we just got our first real snowfall of the year, so it might be because of the cold, the timing is suspicious.
Heater/Fan system was working fine til a couple days ago, when I went to go change the blower settings and the whole thing just died. No fans, when changing settings back and forth from the window to the passenger fans I can hear some faint whirring in the dash like it's trying to start, but then nothing.
Looked at the Fuse box in the engine compartment, #53 had blown. So I replaced it, but it blew again almost immediately after turning on the car. As far as I can tell none of the other fuses are blown, and I'm not sure if there's a way to determine if one of the relays is faulty without changing it (?).
Any idea what could be happening? My guess is a short in the heater/fan system, but that's just a wild guess.
Thanks!
rockfangd
Loc: Utica ny
Reg: 04-13-10
11-04-17 08:08 PM - Post#2713295
    In response to BigDamnArtist
unplug the heater resistor and see if the fuse still blows.
They are very common to failure.
Both the plug and the part itself.
Should be on the passenger side above the passenger side hush panel IIRC
Old School GM fan FOREVER
BigDamnArtist
Reg: 11-04-17
11-06-17 03:46 PM - Post#2713485
    In response to rockfangd
Okay, so good news, I think. I unplugged the blower motor resistor (I couldn't find any reference to a heater resistor, so I think this is the same one), in the passenger wheel well behind the blower motor. Fuse didn't blow, and I got the fans working on the highest setting. Car wouldn't start which I assume is just a safety thing with having that resistor unplugged, so I couldn't check the actual heaters.
So I'm assuming I just need to replace that resistor and I should be good to go?
rockfangd
Loc: Utica ny
Reg: 04-13-10
11-06-17 07:51 PM - Post#2713525
car should start fine with it unplugged.
Yes it is the blower motor resistor.
Assuming you found the right part.
https://www.rockauto.com/info/315/15-8966_Prim ary_...
Edited by rockfangd on 11-06-17 07:53 PM. Reason for edit: No reason given.
BigDamnArtist
Reg: 11-04-17
11-07-17 02:18 PM - Post#2713595
Hmm, strange. That's the part. I was following this video.
https://www.youtube.com/watch?v=vLdMYx6fhic
I'm picking up a new resistor right now. I'll swap it out and see what happens.
rockfangd
Loc: Utica ny
Reg: 04-13-10
11-07-17 06:49 PM - Post#2713622
Thats it. 4 or 5 pin.
held in place by 2 screws IIRC
BigDamnArtist
Reg: 11-04-17
11-08-17 05:37 PM - Post#2713709
Alright, so I (finally) got the resistor swapped out, that rear screw is a real pain to get out. Plugged everything back in, and put a new fuse in, turned the car on, and it's still blowing.
However, the interior lights are now dimming ever so slightly when I'm changing the blower setting which wasn't happening before. So I'm going to take that as a good sign until told otherwise.
The only other thing I can think of is the relay under the hood. But I'm all out of fuses right now to test it.
Edited by BigDamnArtist on 11-08-17 05:42 PM. Reason for edit: No reason given.
rockfangd
Loc: Utica ny
Reg: 04-13-10
11-09-17 07:38 PM - Post#2713852
hmm.
Blower motor is good?
Does it work and sound good?
If it does I would start looking for pinched or chaffed wiring
BigDamnArtist
Reg: 11-04-17
11-12-17 01:53 PM - Post#2714175
Well, I don't know what I did, but I just swapped in a new fuse and the whole system started up perfectly. So I'll take that as a win until it decides to stop working again.
Thanks for your help!
Edited by BigDamnArtist on 11-12-17 01:53 PM. Reason for edit: No reason given.
BigDamnArtist
Reg: 11-04-17
11-12-17 11:33 PM - Post#2714210
It seems that may have been premature. Just went to go start the car and now nothing's working again.
The only thing I can tell is that it was cold outside the first time I tried, and nothing worked, it was warm over the weekend when I tried it and it worked, and it's cold out tonight when it doesn't work. I have no idea if the fuse blew when I just tried, not exactly in the mood to try pulling it at midnight.
It's supposed to be around 0 tomorrow so I'll try again and see if it works.
Any idea what might be temperature sensitive in the system? When I tried it just now, when I turn it to the passenger fans there is a dull whirring noise from the fan ports/dash area like it trying to do something, but then gives up.
rockfangd
Loc: Utica ny
Reg: 04-13-10
11-13-17 06:45 PM - Post#2714301
the blower motor.
If the blower motor is dry, tight, or burnt it may very likely exceed the amperage and blow the fuse.
When it is warmer it is common to work better.
By the way what size fuse are you using?
BigDamnArtist
Reg: 11-04-17
11-13-17 06:57 PM - Post#2714302
Hmm, okay, I'll take a look at that next time I can get in there. The blower motor is the big fan under the glove box yes?
And 30A, same as what was in there originally.
rockfangd
Loc: Utica ny
Reg: 04-13-10
11-13-17 08:03 PM - Post#2714307
yes.
Ok. It takes a bit to pop a 30. the motor could do that though.
It sounds perfectly normal when it is working though?
BigDamnArtist
Reg: 11-04-17
11-16-17 08:12 AM - Post#2714624
Yeah, the motor sounds fine. I'm wondering if it could be the actual blower speed control on the dash? It's been working pretty consistently on the 4 setting for the past few days, but on any other setting it just dies. Completely silent.
It hasn't blown a fuse since that first one after I swapped out the resistor.
RandyGOOT
Reg: 09-13-17
01-23-18 09:09 AM - Post#2721868
Before you start checking the more complicated stuff, trace the wiring and see if there is a nick in one the wires anywhere that is grounding out. By your description it sounds like that could be the case. There's a number of ways that could have happened. Check the easy stuff first.
Execution time: 0.272 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:41 AM
