Join the Community today
Username Post: A TH200 fix        (Topic#348033)
78elk
Reg: 12-23-08
11-03-17 10:22 AM - Post#2713171
What can be done with a TH200 transmission to make it more durable?
11-04-17 03:49 AM - Post#2713234
    In response to 78elk
Hmm, what's going to front of it?
78elk
Reg: 12-23-08
11-04-17 07:39 AM - Post#2713250
It's working okay. I just learned that the 200r4 that I bought off eBay 14 yrs ago is actually a th200. I haven't drove it on highway much, mostly in town. I've been doing the body work on it. I recently read that putting in a shift kit and a deep aluminum pan would make it better than a th350 or th400. I've read this in 2 sites, just want others opinions. Thanks for replying.
11-04-17 04:17 PM - Post#2713282
Not good info, that trans is very weak! Notorious for reverse gear failures and under-engineered for lower power engines.
78elk
Reg: 12-23-08
11-04-17 05:19 PM - Post#2713284
Thanks, I'll have to run it till it breaks. then get the 200r4 I wanted.
11-05-17 04:45 AM - Post#2713311
Good plan, try not to engage reverse at high idle.
11-05-17 04:46 AM - Post#2713312
78elk
Reg: 12-23-08
11-05-17 12:02 PM - Post#2713338
Thanks guys. This engine idles at 700 rpm due to the big cam.
78elk
Reg: 12-23-08
11-09-17 04:19 PM - Post#2713827
Where does one pick up the lockup wires for the TH200c?
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
01-15-18 07:31 PM - Post#2721152
What is a TH200R4? A 200 was a 3 speed. trans. A 700 was a 700R4 and the first 3 speed + overdrive.
01-16-18 11:31 AM - Post#2721201
    In response to Gene_Schneider
http://www.700r4transmissionhq.com/gm-automatic-tr...
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
01-16-18 07:54 PM - Post#2721240
Thank You.....I do not remember that one.
01-16-18 08:22 PM - Post#2721242
You're welcome, Gene.
Execution time: 0.252 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:48 PM
