Join the Community today
Username Post: Installing bolts after paint.        (Topic#348026)
Mick53
Platinum Supporting Member
Mick53
Loc: Northern Indiana
Reg: 04-02-16
11-03-17 05:12 AM - Post#2713144
I'm using polished stainless steel bolts on my entire 53 Chevy pickup.It was brought up to me that I should put some kind of plastic washer behind the bolts to avoid chipping the paint? It seems that this would cause the bolts to work loose? What is the best way to handle this. It will be show paint but I'm going to drive the wheels off of it.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
11-03-17 07:11 AM - Post#2713154
    In response to Mick53
Mick53
Mick53
Reg: 04-02-16
11-05-17 08:19 PM - Post#2713388
    In response to grumpyvette
Thanks Grumpy
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
11-06-17 05:58 AM - Post#2713410
glad too help
Hugomiller
Loc: Florida and UK
Reg: 05-02-17
11-26-17 10:27 AM - Post#2715793
I'm rebuilding an XKE Jaguar - the (painted) front frame is held together with lots of bolts. I got some stainless bolts with a slight shoulder under the head, a bit like a thin washer but smaller than the diameter of the head, so the 'points' on the head don't contact the paint. Jaguar never used washers under these bolts. I actually put the bolts in the lathe & took a bit off the back side of the 'points' to give a bit more clearance. These bolts are pretty standard but you won't notice the 'shoulder' unless you look for it.
Execution time: 0.191 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:27 AM
