Username Post: battery drain?        (Topic#348019)
rod
Loc: kingman,az
Reg: 04-29-00
11-02-17 04:41 PM - Post#2713089
2000 S-10 Blazer. I have been having this problem for several months. I found the sunvisor lites were staying on. I finally cut the wires. now the battery continues to drain. I disconnected the ground for 4 days and the battery only dropped from 12.54 to 12.44. I hooked it back up and over nite it dropped from 12.44 to 11.92. I pulled and checked each dashboard fuse. most read 0. 4 read .02 to .04. the cruise control read .04, why would the cruise read anything, when the switch is off? also some fuse labeled SIR had a .04 drain. I have no idea what that is.
I have not checked anything in the underhood box.
Winter is coming [yes even in Arizona it gets cold] I dont want to have a dead [or almost] some cold morning.
thoughts or help will be greatly appreciated.
Thanks Rod in AZ
SleeperSS
Loc: Spanaway, Wa
Reg: 10-17-04
11-02-17 05:00 PM - Post#2713094
    In response to rod
I had a similar problem on an'83 Z28. Turned out the ecm was drawing 5 volts even when the engine was off.
U.S.C.G. "So others may live"
'96 S-10 SS
'02 BlaZeR2
rod
Loc: kingman,az
Reg: 04-29-00
11-02-17 05:23 PM - Post#2713097
    In response to SleeperSS
so what did you have to do to fix the drain?
thanks Rod in AZ
SleeperSS
Loc: Spanaway, Wa
Reg: 10-17-04
11-02-17 08:42 PM - Post#2713122
    In response to rod
It was under warranty, but I think they swapped it for a new one.
'96 S-10 SS
'02 BlaZeR2
Execution time: 0.944 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:55 PM
