Username Post: EX Pipe        (Topic#347995)
erl71
Reg: 09-11-09
10-31-17 07:22 PM - Post#2712884
Hey
I have a 582ci BBC with dual 3" pipes . Im not happy with the exhaust note it sounds like a boat. So, I would like to run a full x pipe to equalise the sound of each bank but would need major works to pull this off. Can i simply run a 2 1/2" cross pipe and get the same results???
TIA
IgnitionMan
Reg: 04-15-05
11-01-17 01:52 AM - Post#2712901
    In response to erl71
Not really. An X cross handles exhaust a great deal differently than a cross over pipe/tube does.
When I did the first system for my V8 Vega, it was a single cross over, OK, but.....
I then added a second cross over just in front of the muffler's, a slight bit better, still no cigar.
After thinking about it, I redesigned the whole business with a single X pipe.
I now do all my exhaust systems with X pipes.
I make my own X's from merging two 90 degree mandrel bent curved pipes, works nicely. I always use the same diameter pipe for the X as the rest of the system I am building.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
11-01-17 05:40 AM - Post#2712925
    In response to IgnitionMan
Execution time: 0.237 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:22 PM
