Username Post: Front suspension parts        (Topic#347988)
sprog777
Reg: 03-27-10
10-31-17 12:46 PM - Post#2712837
As you can tell by all my post the truck I bought 2001 Silverado z71 was driven but not taken care of so all the wearable items are wore. Does this truck have a 3 or 4 grove pitman arm? Anyone use Detroit axle parts? What is your opinion of this company and would you recommend using there front suspension kit.
sprog777@yahoo.com
1979 K5 Blazer
2001 1500 z71 ext.cab
1999 Chevy Tahoe 4wd
1999 chevy z71 ext.cab
1966 Mustang coupe
1967 rs Camaro
1992 Mazda Miata
2009 ultra classic electra glide
1986 Gli
Hohnsz71
Loc: Dayton Texas
Reg: 02-23-15
11-02-17 07:14 AM - Post#2713040
    In response to sprog777
you have to pull you old one off first to see which one it is (its a bas**d) i used a 2 jaw puller and a center saver on the shaft. I used detroit stuff, its decent, the 3 did not work on my truck, 1999 siverado 4x4.
2012 silverado, bone stock.
sprog777
Reg: 03-27-10
11-02-17 08:09 AM - Post#2713045
    In response to Hohnsz71
Called gm dealer parts dept. He used the last 8 digits of vin and told me it was a 4 groove. The Detroit axle parts come non greaseable no zerks.would like more input before I order their kit. Anyone used their kit? I don't want to have to do this twice looks and sounds like a lot of work.
sprog777@yahoo.com
1979 K5 Blazer
1966 Mustang coupe
1967 rs Camaro
1992 Mazda Miata
1986 Gli
11-02-17 10:35 AM - Post#2713057
Non-greaseable would be a definite no-go for me. Stick to quality brand suspension parts or you will be re-doing it sooner than later.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
11-04-17 05:47 AM - Post#2713238
For steering and suspension parts I won't use anything but Moog. The cheaper stuff you're lucky if you get 6 months.
Jeff
Hohnsz71
Loc: Dayton Texas
Reg: 02-23-15
11-09-17 05:11 AM - Post#2713739
maybe i got a diffrent parts kit than what you are looking at? everything i got from them is greasable.
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
11-11-17 09:19 AM - Post#2714012
My Detroit Axle kit was fully greasable.
Greg
'00 Explorer XLT 4.0 V6 Auto
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
11-11-17 01:02 PM - Post#2714029
    In response to CowboyTrukr
When I looked at the pictures, it looked like maybe there were holes partially hidden, without the zerks installed. My guess is that the parts were handed to a photgrapher and the photographer being an expert in taking pictures, and not autoparts didn't install them.
I find it curious that they claim to actually manufacturer axle shafts and rack and pinions.
99 K3500 RCLB
Hohnsz71
Loc: Dayton Texas
Reg: 02-23-15
11-11-17 04:43 PM - Post#2714055
    In response to 454cid
i just found that the driverside ball joint boot was busted . I ve only had them for 3 months.
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
11-11-17 08:56 PM - Post#2714091
That's an awful short time period. Are you sure you didn't pinch it during installation?
99 K3500 RCLB
Hohnsz71
Loc: Dayton Texas
Reg: 02-23-15
11-12-17 04:50 AM - Post#2714105
None of them where busted.
alschevy
Reg: 04-03-18
04-03-18 11:47 AM - Post#2729817
I have a 2003 2500hd and just did all balljoints, inner and outer tie rods, idler arm and pitman.mine was a 3 spline, and had to take the steering box out and use heat to get it off
sprog777
Reg: 03-27-10
04-07-18 08:57 AM - Post#2730213
    In response to alschevy
Ok I just finished replacing entire front suspension including gear box.While I was under there I did the torsion key lift and put bilstein 5500 mono tube on and now truck drives like new.I was wondering if I use a 1 inch lift on rear will it mess with pinion angle? Truck is now 1 inck higher in front than rear.
sprog777@yahoo.com
1979 K5 Blazer
1966 Mustang coupe
1967 rs Camaro
1992 Mazda Miata
1986 Gli
Execution time: 0.475 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:11 PM
