LMC Truck
Username Post: 2009 Silverado Back-Up Lights        (Topic#347970)
bluegoose
Reg: 12-13-14
10-30-17 05:49 PM - Post#2712746
Hello all. As the title states, I'm in need of some information on the back-up lights on my 2009 2500HD 6.0L (I know this can make a difference in the wiring harness) The problem is that I have no backup lights. They don't come on when I put the truck in reverse, they don't shine when the perimeter lighting is engaged, and there is no power going to the trailer plug when there is supposed to be. I have check the fuses and they are good. I have also run a jumper wire to the fuse and the lights come on. I know the bulbs and sockets are good.
Despite what the google machine says, there is no relay on this particular truck. Does anyone have an idea of what the problem could be?
LMC Trucks
2plus2
Loc: Mission,BC
Reg: 02-03-05
10-30-17 06:18 PM - Post#2712751
    In response to bluegoose
How many fuses did you check?
Gm likes to put a bigger main fuse then one for the trucks backup lights and one for the trailers
69 Canadian Pontiac 2+2
bluegoose
Reg: 12-13-14
10-31-17 09:21 AM - Post#2712814
    In response to 2plus2
I focused on the two red ones (10 amp?) at the bottom right hand corner of the fuse box that are labeled for the truck and trailer backup lights. I have tested them with the truck running in reverse and they are not getting power. Is there another one that I may have overlooked?
In my mind, the easy solution is either another fuse or a backup light switch. The hard being a BCM or even a fuse panel.
Edit: I have had some time to search various parts websites for a backup light switch. I'm seeing that it either threads into the side of the transmission, or it is integrated into the neutral safety switch.....can anyone shed some light on this for me?
Edited by bluegoose on 10-31-17 03:35 PM. Reason for edit: No reason given.
LMC Trucks
Execution time: 0.176 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:27 AM
